Topic "Issue with SFTP"
rog2961
I am trying to script a task within SSIS to transfer files through SFTP. I've used the guide here with
option batch on
open sftp://username:password@company.com:22 -hostkey="ssh-rsa 2048 xx:xx:xx:xx:bd:32:15:b1:cb:cc:c2:c1:71:0d:68:b6"
When attempting to connect through the GUI with the same settings I have no issue. When attemping this through the command line I cannot connect. It will say "Searching for Host..." for about 15 seconds or so, and then "Network Error: connection Timed out" I do not believe this is a network issue as I can connect through GUI. Am using the 5.1.7, windows 7.
Turn on logging for both and compare the logs.
If you won't find the cause, please attach the logs here.
