Topic "SFTP-Command"
free2rhume45
Hi, guys been messing with automating folder synchronization across SFTP my question is my command runs fine but it will not exit upon completion. here is what i have for my script
"C:\Program Files\WinSCP\WinSCP.com" /command "option confirm off" "open _______@_______ " "synchronize remote -filemask="*.xml" _________\________\ /________/ ""exit"
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
