Topic "File Compare in v5.2.4 is inactive"
Max
In last beta build (3548) "File Compare" command is not active in panels. Only in "Synhronize" window.
You need to have files to compare selected in both file panels. That means the command is not available in an Explorer interface (if case you are using it).
Or does your reference to the "last beta build" indicate this stopped working after you upgraded?
Max
Yes. I talk about last beta. In previous version this feature worked as expected.
http://winscp.net/tracker/show_bug.cgi?id=1071
