Topic "No reconnect when connection is dropped - Batch"
SanchesMatheus
Dears,
I created a script file and I need if he lose connection abort the transfer.
My script:
winscp /command "option confirm off" "open sftp://User:Pasword@SFPTServer" "cd dir" "put file" exit /log=File.log
Matheus Sanches
Use option batch abort at the beginning of the script (as all samples on this site recommend).
For instance: http://winscp.net/eng/docs/scripting#using_scripting
rmtarget
option batch abort does not work for me (in my script)!!
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
