Topic "How to write script for SSL FTP connection"
ttian
open ftp://user:1password@ftpsite.com
waiting for welcome message
connection failed
connection failed
policy requires SSL
assume the command line is incorrect.
ttian
here is the script:
winscp ftp://user:password@myftp.com /explicitssl
option batch abort
option transfer binary
put c:\test\*
close
the site will connected, after it nothing going on. (from "option batch abort" below nothing runs)
please help! thank you!
ttian wrote:
here is the script:
option batch abort
put c:\test\*
close
What kind of script is this? While the first line is Windows command (to run WinSCP), the rest are WinSCP commands. You cannot combine these in a single file/script.
Please start again with:
http://winscp.net/eng/docs/scripting
http://winscp.net/eng/docs/guide_automation
Hi Prikryl,
Thank you for your reply. The actual script as below:
option batch abort
put c:\test\*
close
when I run it, it shows the site connects, and then stop there, which means the rest of commands won't run. I'm kind of stuck here.
Please help! Thanks again!
First, I already suggested you that you cannot combine Windows command (to run WinSCP) and WinSCP commands in one script. What obviously your script is doing. Second, you did not answer my question. What kind of script the above is? Is is a .bat file? If it is, make sure you move the remaining commands to a WinSCP script file and reference the file from WinSCP command-line. For that refer to the links I've posted earlier.
