Topic "connection drop outs"
i get this in my log:
. WinSCP Version 3.6.1 (Build 221) (OS 5.1.2600 Service Pack 1)
. Login time: 19 May 2004 21:38:49
. Session name: gophers
. Host name: (Port: 22)
. User name: root (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Cache directory changes: Yes, Permanent: Yes
. Looking up host ""
. Connecting to port 22
. Server version: SSH-2.0-OpenSSH_3.8.1p1 Debian 1:3.8.1p1-1
. We claim version: SSH-2.0-WinSCP-release-3.6.1
. Host key fingerprint is:
. ssh-rsa 1024 7d:e1:b5:07:c6:9f:2d:c7:20:9b:f2:84:50:43:93:ff
. Waiting for data timed out, asking user what to do.
. Asking user:
. Host hasn't answered for 15 seconds.
. Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
when i hit the retry it usually connects and then i do a file transfer from my windows machine to my linux machine. except i am getting speeds of about 250B/s Sad
anyone else get this?
because i am stressed out, i forgot to mention that this is over my lan which is 100meg. i can easily ssh to my linux box with no lag and tcptraceroute is ok so i dont know whats going on.
Have you tried other SFTP client? Can you try PuTTY SSH client and PSFTP?
I'll try tonight when i get home from work.
FYI both the switch and the two network cards in the respective machines are all running at 100 full duplex.
| linux@work|
// <-the interweb
| 4-port adsl |
| router/switch |---------------,
----------V--------............... --------V------
| linux@home |............| XP@home |
what i am trying to do is transfer from XP@home to linux@home using scp
if i do a file transfer or receive between linux@home and linux@work it works fine and the speed is very adequate.
i havent been able to see what happens if i do a transfer from the linux@home to the XP@home machine. i would have thought it's safe to presume that; if the transfer between the linux@home to the linux@work is working that the problem rests with the XP@home machine.
so to sum up:
if linux@home is the server-
a transfer from linux@home to linux@work = fast
a transfer to linux@home from XP@home = slow
a transfer to linux@home from linux@work = fast
Tonight i'll try pscp from XP@home to linux@home. If that works do you know what that would mean? what information do you want to see next if this is the case?
