Topic "basic questation"
Falcong
Hi sorry for my bad englisch. Exist solution which I use define session from ini file and commands in the file ? I want define proxy server , connection in the ini file , call winscp with this , using defined parametr from GUI , and attach script to copied files ?
thank you very much
If you want to write a script to automate file transfer, see:
http://winscp.net/eng/docs/guide_automation
For configuring a proxy, see:
http://winscp.net/eng/docs/rawsettings
Falcong
dobry den,
dekuji za odpoved . Urcite zkouknu . Jednalo se mi o to ze sem chtel nastavit ini soubor kde bude preddefinovana hodnota a treba i pro sftp otisk certifikatu . a zaroven mu vnutit soubor ktery se bude zpracovavat ...
Otisk certifikatu se da zadat primo v prikazu open:
http://winscp.net/eng/docs/scriptcommand_open
Parametricke skripty (pro predani jmena souboru) jsou take mozne:
http://winscp.net/eng/docs/scripting#syntax
http://winscp.net/eng/docs/commandline#scripting
Falcong
Dik Smile
