Topic "possible to increment/decrement a date/number in script?"
Hi. I'm looking to use WinSCP as a do-everything FTP client using scripting. I've gone through the scripting area of the site as much as I can but didn't find an answer to the following questions.
1. I need to be able to recognize different date formats in the filename.
Examples: yyyy or yy for year
mmm or mm for month
dd for day
Sample filename formats: filename_yyyymmdd.txt or filename_ddmmmyy.txt
2. I need to be able to increment/decrement the date by varying amounts from the current date (example: today, Dec. 5, 2013). So for example, I would pass a parameter like +1 to increment the date that WinSCP would look for by 1 (tomorrow's date - filename_20131206.txt). Similarly, a -1 would look for the day before the current date (filename_20131204.txt).
3. I need to be able to also increment a number in the filename from a certain starting number that has a starting date attached to it. The number would have to be incremented automatically based on how long ago from today the starting date was.
For example:
Starting number: 1
Starting date: Dec. 1, 2013
So when the script runs, it checks current date (Dec. 5, 2013). It sees the current date is 4 days after the starting date and will increment the starting number by the same amount. So the filename would look something like filename_yyyymmdd_nn.txt (filename_20131205_05.txt).
Thanks for any help you can provide.
This is definitely not something WinSCP can do for you.
You need to implement this using some scripting language.
See this example for inspiration:
