Topic "Spaces in filenames..."
Floatingshed
I need to occasionally delete a remote file so I've written a simple gui that inserts the filename into a command line and executes it. This is my command line:
"c:\Program Files\winscp\winscp.com" /command "option batch abort" "option confirm off" "open ftp://password:username@server.com" "rm /Temp/File_to_delete.plp" "exit"
It works fine unless the filename has any spaces in it. In that case I get a file not found error, normally this is fixed by putting the whole filename and path in quotes, but it already is!
Any help much appreciated.
See
http://winscp.net/eng/docs/commandline#syntax
I.e. the correct syntax is:
"c:\Program Files\winscp\winscp.com" /command "option batch abort" "option confirm off" "open ftp://password:username@server.com" "rm ""/Temp/File_to_delete.plp""" "exit"
Excellent, works a treat. Thanks
