Topic "How to set TLS/SSL options"
Dominion
How can i set the settings displayed here:
http://winscp.net/eng/docs/ui_login_tls
I have a connection problem using the .NET assembly (SSL handshake), when using the GUI i can force to use SSL 3.0 for both minimum and maximum and then the connection succeeds, but still unable to connect using the assembly
Dominion
I have found it, you can use the RawSettings options and set both MinTlsVersion and MaxTlsVersion to value 3 (which works for me)
For others:
http://winscp.net/eng/docs/rawsettings
