Topic "Accessed denied using Winscp 5.5.1"
Xdeveloper55
When I attempt to login to my sftp server using Winscp 5.5.1 after entering my password I immediately get access denied. My password has the @ special character. The first attempted using the special character @ in the password. The result was a failure "access denied". The second attempt I encoded the special character @ to %40. Again the result was a failure "access denied." What could I be doing wrong? Thanks in advance for all your help.
Mike
If you are connecting from GUI, no escaping for @ is needed.
Is it SFTP or FTP?
Xdeveloper55
Is it SFTP or FTP?
I'm using sftp.
OK, are you able to connect with another SSH client, like PuTTY?
Let me apologize for the delayed response. I was sick for the past month. Yes, I was able to login using the GUI and recently I was able to.connect using code after the pw was changed to not use certain special characters. I will download the recent released version and test using the special characters translated with utf-8 as my next task. I will follow up with the results. Again thanks.
