Topic "Delete files on upload the files"
mehdi.rahimi
I wrote a piece of code using variety of sample scripts available on the net and still have an issue deleting the files after they get uploaded on a remote location. Please help as Im meeting my deadlines... No matters where I put remove files, I always get Exception calling "RemoveFiles" with "1" argument(s): "Recursive calls not allowed"
      [Reflection.Assembly]::LoadFrom("C:\Program Files\WinSCP\WinSCPnet.dll") | Out-Null
     # Session.FileTransferred event handler
function FileTransferred
    Param($e)
    if ($e.Error -eq $Null)
        Write-Host ("Upload of {0} succeeded" -f $e.FileName)
       #If Download succeeded, remove the files from source
    else
        Write-Host ("Upload of {0} failed: {1}" -f $e.FileName, $e.Error)
    if ($e.Chmod -ne $Null)
        if ($e.Chmod.Error -eq $Null)
            Write-Host ("Permisions of {0} set to {1}" -f $e.Chmod.FileName, $e.Chmod.FilePermissions)
        else
            Write-Host ("Setting permissions of {0} failed: {1}" -f $e.Chmod.FileName, $e.Chmod.Error)
    else
        Write-Host ("Permissions of {0} kept with their defaults" -f $e.Destination)
    if ($e.Touch -ne $Null)
        if ($e.Touch.Error -eq $Null)
            Write-Host ("Timestamp of {0} set to {1}" -f $e.Touch.FileName, $e.Touch.LastWriteTime)
        else
            Write-Host ("Setting timestamp of {0} failed: {1}" -f $e.Touch.FileName, $e.Touch.Error)
    else
        # This should never happen with Session.SynchronizeDirectories
        Write-Host ("Timestamp of {0} kept with its default (current time)" -f $e.Destination)
   foreach ($e in $synchronizationResult.uploads)
             $removalResult = $session.RemoveFiles($session.EscapeFileMask($e.FileName))
                if ($removalResult.IsSuccess)
                    Write-Host ("Removing of file {0} succeeded" -f
                        $e.FileName)
                else
                    Write-Host ("Removing of file {0} failed" -f
                        $e.FileName)
     # Main script
try
      $sessionOptions.Protocol = [WinSCP.Protocol]::sftp
      $sessionOptions.PortNumber = 9922
      $sessionOptions.Timeout = "120"
      $sessionOptions.HostName = "123456"
      $sessionOptions.UserName = "123456"
      $sessionOptions.Password = "123456"
     $sessionOptions.SshHostKeyFingerprint = "123456"
    try
        $localPath = "C:\Users\rahimm\Desktop\TestSftpLocation\"
        $remotePath = "/Oresponces/"
      # Will continuously report progress of synchronization
        $session.add_FileTransferred( { FileTransferred($_) } )
        # Connect
        # Synchronize files
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Remote, $localPath, $remotePath, $False)
        # Throw on any error
        $synchronizationResult.Check()
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
You cannot call back into Session from event handlers.
Moreover your code does not make sense. You should move your foreach ($e in $synchronizationResult.uploads) loop to main block after $session.SynchronizeDirectories finishes.
nealobrien
I need the same feature as noted by the op:
1. sync that mirrors all file movements and deletes (on both local or remote) - this greatly preferred
2. a command or succinct script to move files to the server (but not copy, ie put or get)
Does this exist or are there plans to support it?
Many thanks
WinSCP does not keep any data about previous state of the folders. Without that:
- If file is existing one side, but missing on the other, how do you tell if it was added on one side or deleted on the other?
- If new file is present on one side and another file is absent, how do you tell if it was rename or simply new file added and another removed?
I do not understand. Please elaborate.
nealobrien
We need "synchronise both" to also delete in both directions. Or, for synchronise local to also delete local when remote is moved/deleted & conversely for synchronise remote to also delete remote when local file is moved/deleted. Im pretty sure Winscp could do this, but as this feature seems not to be offered yet, is there a recommendation on the simplest solution?
The reason we need this is because files are produced one machine yet are consumed (processed) on the other server, and it happens in both directions. Its basically messaging with files.
I understand. I asked you how do you image this could be implemented.
That's what -delete switch does.
http://winscp.net/eng/docs/scriptcommand_synchronize
nealobrien
If I read your second answer correctly, "That's what -delete switch does.", then we're okay. But I thought -delete will delete from target only when a file is deleted in source, no?
As to the first note, winscp could implement this by polling both directories and when a file appears in one it copies it to the other, and when a file is deleted in one it deletes in the other. As long as state is maintained by winscp this seems possible:
1. Upon start synchronise, then load a hash of both local and remote
2. Every x seconds, poll local and remote, and load file list to a tmp_hash (really one for each directory)
3. For both local and remote, for each directory, compare tmp_hash with orig_hash
for each new file in tmp_hash
add to the other
for each missing file in tmp_hash
delete from the other
set orig_hash = tmp_hash
It deletes file from target when it does not exist in source (no matter if it ever existed there or not).
Of course. But that's a completely different function that what we have atm.
nealobrien
Well it appears you have answered this here:
http://winscp.net/eng/docs/faq_delete_synchronized_files
well almost the same, close enough, so thank you!
