Property 'WinSCP.TransferOptions.ResumeSupport' lacks setter
dialalpha
Attempting to use the C# dll to incorporate winscp into an App. According to the documentation, we can configure transfer options by creating a TransferOptions class and setting its ResumeSupport property. However, the error below is what happens when you try that -
Error: Property or indexer 'WinSCP.TransferOptions.ResumeSupport' cannot be assigned to -- it is read only
Examining the class via the object browser reveals that indeed the property doesn't have a setter. (screenshot attached)
I'm using dll version number 1.1.5.4214 and runtime version v2.0.50727
Is this a bug or is it intentional?
fpreich
Powershell: WinSCP.TransferOptions.ResumeSupport
Can't find this object in Powershell:
$transferOptions.ResumeSupport
Property 'ResumeSupport' cannot be found on this object. Make sure that it exists.
What's the syntax to set it to TransferResumeSupportState.On ?
Thanks in advance
FP
Re: Powershell: WinSCP.TransferOptions.ResumeSupport
You may be using an old version of WinSCP .NET assembly that lacks the TransferOptions.ResumeSupport property. Make sure you have the latest version.
fpreich
Yes, this helps !
Thanks Martin,
appreciate your great work.
