Topic "Transfer Fail/Success"
NoName
Whats the easiest way to use the Exit code to highlight a problem with a file upload?
I have very limited coding skills!
See http://winscp.net/eng/docs/guide_automation#results
NoName
Thanks but I have to launch WINSCP using the following due to my company configuration and cant use WINSCP.com
"C:\Program Files\Microsoft Application Virtualization Client\sfttray.exe" /launch "WinSCP 5.1.7.3446" /console /script=C:\Users\spy\desktop\spyscript.txt
This doesn't seem to allow goto statements & errorlevel options?
I suppose you can run a batch file using sfttray.exe, instead of WinSCP directly.
NoName
Thanks Martin, unfortunatly I cant get this to work Sad
Should I use the Errorlevel code in the Script file or the Batch file?
Sorry, I do not know sfttray so I cannot give you more detailed answer.
