Automated task fails when interactive OK
Jiri Hovorka
When I use WinSCP in interactive mode, everything works perfect (upload, download, file deletion).
Scripting the same task fails when uploading files in WinSCP versions 5.5.3 b4214 and 5.1.5 b3261 - log with comments is included. Transfer fails with Status code: 2, Message: 2563, Server: File not found.
I have tried put/mput with all the options explicitly (no combination worked) and setting everything in the INI file with no luck. Pitty is, that the server does not let me open console:(
Maybe I overlooked something stupid:) Can you please help?
Free beer for the help!
Description: a part of the log with comments
Re: Automated task fails when interactive OK
The problem might by that you are using backslash in remote path instead of forward slash: put readme.txt .\
Jiri Hovorka
...ohhh my! - 5 people looked into it and overlooked just one little character:)
put readme.txt ./ worked
The beer is yours - i will write to your email.
