Topic "drag and drop files to correct target monitor"
When dragging files from WinSCP (v5.5.3) to the desktop, application ignores which monitor file was targeted to. File always manifests on primary screen. I find this annoying because my main monitor is littered with Windows. Consequently, I need to minimize everything before I can access copied file [from desktop]. It'd be more convenient if WinSCP forced file to appear exactly where it was dropped. That's how Windows Explorer and WinZIP both behave.
This is a drawback of WinSCP using drag&drop shell extension to find out where you dropped the files to.
You can switch to "temporary folder" mode:
