Topic "Log not reporting status code "226 Transfer complete""
thommck
We are replacing an native Winsdows FTP with an SFTP process using WinSCP.com.
Out old FTP log files would show the staus code "226 Transfer complete" on a successful get or put command
However, I can't see if this is being logged in the new WinSCP script.
Is it not supported or do I need to look somewhere else for this?
Batch Script
"c:\Program Files\WinSCP\WinSCP.com" /script="c:\temp\get-test.txt" /log="c:\temp\get-test.log" /xmllog="c:\temp\get-test.xml"
WinSCP Script
option batch abort
open sftp://xxxx@website.xxxxx.com/ -hostkey="ssh-rsa 2048 XX:XX:16:aa:56:0d:14:44:91:26:bc:33:e9:d5:66:45"
get /folder/outgoing/test.txt c:\temp\
close
I have tried setting the logging level to Debug 1 and 2 but it still won't report "226 Transfer complete" anywhere.
I have seen the code appear in other users logs on this forum so I'm hoping it is just an option I can set somewhere to include it
The 226 is FTP protocol status code. You are using SFTP protocol now.
Anyway, you should not parse the log file to determine if transfer was successful or not.
Test WinSCP exit code instead. See http://winscp.net/eng/docs/faq_script_result
thommck
I had a feeling that was the case so thanks for the clarification
