Topic "Files not copying"
ckchinetworks
So I have a script and it runs great for the most part, there is a new issue though. I have the script run every night and finishes in 30 mins after going through 550+ GB of data. This has been running for about 3 weeks now, but lately I found the files are not being copied over. In the logs it identifies new and modified files but they are not making to the destination directory. There are no errors for reading the source or destination folder. Any ideas on what is going on?
ckchinetworks
The log is very large, it will be sent in 2 parts.
backup.zip (5.99 MB) Private file
Description: (none)
ckchinetworks
part 2
backup_part2.tar (6 MB) Private file
Description: (none)
Sorry, but I do not know what to do with those files. The backup.zip.zip file is not a valid ZIP file. And the backup_part2.tar file also does not look like a valid TAR file.
ckchinetworks
OK, I manually split the files and created new rar files. It's in 2 parts again.
backup_1.rar (5.84 MB) Private file
Description: (none)
ckchinetworks
part 2
backup_2.rar (5.32 MB) Private file
Description: (none)
I see you have 7 synchronize commands in your scripts.
Some do not find any change to synchronize.
Some find a change and do synchronize it.
And two of them fail for different reasons:
Quote:
> 2014-10-07 00:09:34.563 CWD /HomeFolder/Robert.Meixner/Desktop/
< 2014-10-07 00:09:34.578 550 Access is denied.
Quote:
. 2014-10-07 00:12:06.538 Can't open file 'G:\Share\Prior Sever appraiser and map.it\Software to install\Software for new Katrina machine 2011-10-28\Sharp MX-5001 Win 7 64-bit (2011 Oct 28)\CFSC-PCFAX-1010A-2KXPVISTAXPVISTAX64\CFSC-PCFAX-1010a-2kxpVistaXPVistax64\CFSC-PCFAX-1010a-2kxpVistaXPVistax64.txt'.
. 2014-10-07 00:12:06.538 Copying files from remote side failed.
The second error is probably because of a too long path. WinSCP does not support paths longer than 260 characters with FTP protocol:
http://winscp.net/tracker/show_bug.cgi?id=821
ckchinetworks
Sorry I got busy before I had a chance to reply, the directory with the issue is "share\public reports\reports"
That's caused by the second error in my previous post.
Michal Sokolowski
Hey, thank u for that great piece of software, I've successfully implemented it for lots of users. Do u have any plans to fix FTP deep path as well?
eine
Anonymous wrote:
Just, CC, I've registered myself.
Sorry for double post, I've just found notifications, please delete it.
