Topic "Variable uses an Automation type not supported in VBScript"
nyhack44
I am trying to use the VBScript ListDirectory example and I am getting an error:
Line 31
Line 31 is :
WScript.Echo fileInfo.Name & " with size " & fileInfo.Length & _
", permissions " & fileInfo.FilePermissions & _
" and last modification at " & fileInfo.LastWriteTime
Can someone please tell me if I am doing something wrong? I use VB script in WSF files for getting and putting files all the time, and they work fine. For the life of me, I can't get list directory to work.
Mark
<job>
<reference object="WinSCP.Session"/>
<script language="VBScript">
Option Explicit
' Setup session options
Dim sessionOptions
Set sessionOptions = WScript.CreateObject("WinSCP.SessionOptions")
With sessionOptions
    .Protocol = Protocol_Sftp
    .HostName = <hostname>
    .UserName = <username>
    .Password = <password>
    .SshHostKeyFingerprint = <SSH Key>
End With
Dim session
Set session = WScript.CreateObject("WinSCP.Session")
' Connect
session.Open sessionOptions
Dim directoryInfo
Set directoryInfo = session.ListDirectory("/home/martin/public_html")
Dim fileInfo
For Each fileInfo In directoryInfo.Files
Next
' Disconnect, clean up
session.Dispose
</script>
</job>
http://winscp.net/tracker/show_bug.cgi?id=1231
I'll send you a dev version for testing shortly to an address you have used to register on this forum.
