Topic "Folder Sync - tagging completed folders (upload file)"
CinnTech
I currently have the below script which works great. The problem is I have to manually upload a 'completed.txt' file to mark the folder as completed.
I was wondering if there is a way to automate this once the current folder has been marked as synced? I'm aware that winscp only checks files and not directories so just checking if there is another solution.
# This script will login to a SFTP and download/sync new files via WINSCP.
# - Once a folder is synced it will upload a completed file so you can move the local folder.
# - If the remote folder is emptied it will remove the completed file and the folder.
# - This script is intended to be put in a scheduled task.
# - v1.0
   # SET THE VARIABLES
   $downloadPath = "s:\Downloads"
   $remotePath = "/home/downloads"
   $drivePath = "s:" #this can be a network drive and should be the same as download path drive.
   $checkFile = "completed.txt" #change this to what file you want to tag the folder and skip it.
   $logFile = "$drivePath\torSync.log" #where you want your log file saved.
   $hostName = "ftp.server.com"
   $userName = "ftpuser" #ftp
   $passWord = "ftppass" #ftp
   $mapUser = "uncuser" #username to map network drive
   $mapPass = "uncpass" #password to map network drive
   $mapPath = "\\networkpath"
   $sshKey = "ssh-rsa 2048 yoursshkey (it's like xx:xx:xx: etc)"
   $winscpPath = "C:\Program Files (x86)\WinSCP"
    $localIp = "0.0.0.0" #if you want to force a VPN put your public static IP here. If you don't have a Static IP change the script to -> if (!($myIp -eq $localIp)) <- and put your VPNs static IP here (otherwise put 0.0.0.0 or some bogus IP, and it will not check VPN status).
   $countFiles = 0 #Don't change this.
   $((Get-Date).DateTime) #this will show the date on screen.
   #This is to map network drive if not already mapped.
   if (!([System.IO.Directory]::Exists("$drivePath\")))
      net use $drivePath $mapPath /user:$mapUser $mapPass /persistent:yes
   #Disable these to disable WinSCP logging.
   # $WinSCPDebugLogFile = "s:\WinSCPDebugLogFile.txt"
   # $WinSCPSessionLogFile = "s:\WinSCPSessionLogFile.txt"
   # $WinSCPXMLLogFile = "s:\WinSCPXMLLogFile.xml"
   # START the Email Log File
   Write-Output "" >> $logFile
   Write-Output "Synchronization Started"  >> $logFile
#Let's verify we're on our VPN
 function Get-ExternalIP {
(Invoke-WebRequest ifconfig.me/ip).Content
$myIp1 = Get-ExternalIP
$myIp = $myIp1.replace("`n","")
 if ($myIp -eq $localIp)
   Write-Output "--> Your not connected to the VPN $myIp <--" >> $logFile
else
   #WINSCP
      try {
         [Reflection.Assembly]::LoadFile("$winscpPath\WinSCPnet.dll") | Out-Null
      } catch {
         Write-Error "$winscpPathwinSCPnet.dll failed to load, you must have WinSCP 5.20+ installed with the .NET assembly."
       # Session.FileTransferred event handler
      function FileTransferred
         Param($e)
         if ($e.Error -eq $Null)
            Write-Output ("$currentTime || Download of {0} succeeded " -f $e.FileName) >> $logFile
         else
            Write-Output ("$currentTime || Download of {0} failed: {1}" -f $e.FileName, $e.Error) >> $logFile
      function FileTransferProgress # This won't show in the window if Scheduled Task running without a logged in user.
         Param($e)
         # New line for every new file
         if (($script:lastFileName -ne $Null) -and
            ($script:lastFileName -ne $e.FileName))
             Write-Host
         # Print transfer progress (shows in window only - not in log file :( )
         Write-Progress  ("`r{0} ({1:P0})" -f $e.FileName, $e.FileProgress)
         # Remember a name of the last file reported
         $script:lastFileName = $e.FileName
      # Main script
      $script:lastFileName = $Null
      try
         $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
         $sessionOptions.HostName = $hostName
         $sessionOptions.UserName = $userName
         $sessionOptions.Password = $passWord
         $sessionOptions.SshHostKeyFingerprint = $sshKey
         try
            # Will continuously report progress of synchronization
            $session.add_FileTransferred( { FileTransferred($_) } )
            $session.add_FileTransferProgress( { FileTransferProgress($_) } )
            # Setup session log files locations
            $session.DebugLogPath = $WinSCPDebugLogFile
            $session.SessionLogPath = $WinSCPSessionLogFile
            $session.XMLLogPath = $WinSCPXMLLogFile
            # Connect
             #Get a list of remote folders & sort them.
            $directory = $session.ListDirectory("$remotePath")
            foreach ($fileInfo in $directory.Files |  Sort-Object { [regex]::Replace($_.Name, '\d+', { $args[0].Value.PadLeft(20) }) })
            $currentTime = Get-Date
               # Write-Host ("{0}" -f $fileInfo.Name)  >> $logFile
               $currentFolder =    ("{0}" -f $fileInfo.Name)
               # I don't want to sync . or .. as it will sync everything. Also, ignoring .htaccess file
               if (!($currentFolder -eq "." -or $currentFolder -eq ".." -or $currentFolder -eq ".htaccess"))
                  #check to see if current folder is completed first.
                  $completedCheck = "$remotePath/$currentFolder/$checkFile"
                  if ($session.FileExists($completedCheck))
                     # Now let's see if it's the only file in the folder remove the file and the folder if it is.
                     # Gel list of files in the directory
                     $wildcard = "*.*" #we want to list all files
                     $directory = $session.ListDirectory("$remotePath/$currentFolder")
                     #let's count the files and omit [.] and [..] (there should be no .htaccess files) if there is then we have to add that to the script.
                           Where-Object { $_.Name -Like $wildcard -AND $_.Name -NotLike "." -AND $_.Name -NotLike ".."})
                           #this is for testing.
                           $countFiles++
                     if ($countFiles -gt 1)
                         Write-Output ("$currentTime || SKIPPING - FOLDER NOT EMPTY || $currentFolder || File {0} exists " -f $completedCheck)  >> $logFile
                        elseif ($countFiles -eq 1)
                           Write-Output ("$currentTime || DELETING - FOLDER WAS EMPTY || $currentFolder || File {0} was the only thing to exist" -f $completedCheck)  >> $logFile
                           $removalFileResult = $session.RemoveFiles("$completedCheck")
                           $removalDirResult = $session.RemoveFiles("$remotePath/$currentFolder/")
                            if ($removalFileResult.IsSuccess)
                              Write-Output ("$currentTime || DELETE file completed.txt SUCCESS")  >> $logFile
                           else
                              Write-Output ("$currentTime || !! DELETE FAILED !!")  >> $logFile
                           if ($removalDirResult.IsSuccess)
                              Write-Output ("$currentTime || DELETE FOLDER SUCCESS")  >> $logFile
                           else
                              Write-Output ("$currentTime || !! DELETE FOLDER FAILED !!")  >> $logFile
                     else
                        Write-Output ("$currentTime || ERROR in count files")  >> $logFile
                  # If we don't find the 'skip' then sync this folder
                  else
                     # Create folder if it doesn't exist
                     if (!(Test-Path -Path "$downloadPath\$currentFolder" -ErrorAction SilentlyContinue ))
                        New-Item "$downloadPath\$currentFolder" -Type Directory -ErrorAction SilentlyContinue
                        Write-Output "$currentTime || FOLDER CREATED || $downloadPath\$currentFolder" >> $logFile
                     # Now let's synchronize the files in the folder.
                     Write-Output "$currentTime || Currently Syncing || $remotePath\$currentFolder to || $downloadPath\$currentFolder"  >> $logFile
                     $synchronizationResult = $session.SynchronizeDirectories(
                        [WinSCP.SynchronizationMode]::Local, "$downloadPath\$currentFolder", "$remotePath/$currentFolder", $False, [WinSCP.SynchronizationCriteria]::Either)
                     # If the folder has finished synchronization then upload the 'skip' file so we can move the folder locally.
                     if ($synchronizationResult)
                        $session.PutFiles("$drivePath\$checkFile", "$remotePath/$currentFolder/$checkFile",$False)
                        Write-Output "$currentTime || FOLDER COMPLETED and uploaded $checkFile to $remotePath/$currentFolder" >> $logFile
                     # Throw on any error
                      $synchronizationResult.Check()
         finally
             # Terminate line after the last file (if any)
            if ($script:lastFileName -ne $Null)
                Write-Host
            # Disconnect, clean up
            $session.Dispose()
         exit 0
   catch [Exception]
      Write-Output $_.Exception.Message >> $logFile
      exit 1
** I've updated the code as it is now working as intended - so putting here for other's.
I'm not sure if I understand a problem. Are you asking how to create a file in remote directory (i.e. upload an empty file) "completed.txt" to the server?
I'm just wondering if there is a way to check if/when all contents of the folder are synced - if they are - then upload the file automatically. Currently I have to manually monitor (via log file or otherwise); when a folder is synced I manually upload the 'completed.txt' file. Then I can move the local copy and not have it sync again.
Does WINSCP give a true/false return if a file is synced? Maybe I could do a count files on a folder and a count for true and compare, if they equal upload a file?
The synchronization is finished when Session.SynchronizeDirectories finishes. Just follow it by Session.PutFiles.
That worked, thanks!
