Topic "WebDAV two-factor authentication"
walvarezf
Hi. Im using the latest beta (5.6.2 build 4756).
I'm succesfully using the WebDav functionality, however, I do not see options to set up the "own certificate, public key, and passphrase) in order to enable two-factor authentication for enhanced security.
I've used private keys, pre-accepted host keys and remote certificates, but I dont see options compatible for WebDav two-factor authentication.
do you have any plans to implement this, or maybe you already have and I can't figure it out?
Thanks.
Thanks for your post.
This request is being tracked already:
http://winscp.net/tracker/show_bug.cgi?id=921
I have sent you an email with a development version for testing.
chv.const
WinSCP 5.7.4 (Build 5553)
I'm busy with the same issue.
Need a Client with two factor Authentication (and User/Password) on a WebDAV connection.
Could I get a portable version with these options available please?
Sent.
chv.const
Thanks alot.
Still figuring out how to get proper certificate to use.
However, you got bug report: http://winscp.net/forum/viewtopic.php?p=58225#58225
