Topic "Test-Path -exclude equivalent for remote path."
I'm wondering if there is a powershell:
test-path c:\* -exclude test.txt
equivalent for remote folders?
I know I can find the existence of one file using:
$remotePath = "/home/user/test.txt"
if ($session.FileExists($remotePath))
    Write-Host ("File {0} exists" -f $remotePath)
but I want to find out if 1 specific file exists only - in a specific folder. (basically: if there is more then the specified file, return true; if it's just the one file, return false)
Thanks.
$files = $session.ListDirectory("/home/user").Files | Where-Object { (-not $_.IsDirectory) -and ($_.Name -ne "test.txt") }
if ($files)
    Write-Host "Files " $files " found"
See http://winscp.net/eng/docs/library_example_listing_files_matching_wildcard
