Topic "Not recognized listing format from toolbox ls command"
jkk88
When try to connect to android cyanogenmod builtin ssh server (version 11 but probably all) by using SCP protocol I get only
Unexpected directory listing line 'drwxr-xr-x root root 1970-02-03 01:41 acct'.
Workaround is to set "busybox ls -la" in directory listing command advanced session configuration.
Here is example for format used by ls -la issued in root directory:
root@C1905:/ # ls -l `which ls`
lrwxrwxrwx root     root              1970-01-23 22:09 ls -> toolbox
root@C1905:/ # ls -la
-rw------- root     root            2 2014-12-28 15:18 boot.chk
-rw-r--r-- root     root          102 1970-02-03 01:41 boot.txt
drwxrwx--x system   cache             2014-12-17 23:58 cache
-rwxr-x--- root     root       284704 1970-02-03 01:41 charger
dr-x------ root     root              1970-02-03 01:41 config
lrwxrwxrwx root     root              1970-02-03 01:41 d -> /sys/kernel/debug
drwxrwx--x system   system            2014-12-28 15:16 data
-rw-r--r-- root     root          136 1970-02-03 01:41 default.prop
drwxr-xr-x root     root              2014-12-28 15:18 dev
lrwxrwxrwx root     root              1970-02-03 01:41 etc -> /system/etc
lrwxrwxrwx root     root              1970-02-03 01:41 ext_card -> /storage/sdcard1
-rw-r--r-- root     root        11071 1970-02-03 01:41 file_contexts
dr-xr-x--- system   system            1970-01-01 01:00 firmware
-rw-r----- root     root         1208 1970-02-03 01:41 fstab.qcom
-rwxr-x--- root     root       187840 1970-02-03 01:41 init
-rwxr-x--- root     root         1822 1970-02-03 01:41 init.class_main.sh
-rwxr-x--- root     root         6622 1970-02-03 01:41 init.cm.rc
-rwxr-x--- root     root          992 1970-02-03 01:41 init.environ.rc
-rwxr-x--- root     root        20490 1970-02-03 01:41 init.qcom.rc
-rwxr-x--- root     root         5735 1970-02-03 01:41 init.qcom.usb.rc
-rwxr-x--- root     root        22030 1970-02-03 01:41 init.rc
-rwxr-x--- root     root          341 1970-02-03 01:41 init.recovery.qcom.rc
-rwxr-x--- root     root          301 1970-02-03 01:41 init.superuser.rc
-rwxr-x--- root     root        12056 1970-02-03 01:41 init.target.rc
-rwxr-x--- root     root         1795 1970-02-03 01:41 init.trace.rc
-rwxr-x--- root     root         3915 1970-02-03 01:41 init.usb.rc
-rw-r--r-- root     root         7660 1970-01-01 01:00 logo.rle
drwxr-xr-x root     root              1970-01-01 01:00 lta-label
drwxrwxr-x root     system            1970-02-03 01:41 mnt
drwxrwx--x system   system            2009-01-02 14:00 persist
dr-xr-xr-x root     root              1970-01-01 01:00 proc
-rw-r--r-- root     root         2161 1970-02-03 01:41 property_contexts
drwxr-xr-x root     root              1970-02-03 01:41 res
drwx------ root     root              2014-12-17 22:13 root
drwxr-x--- root     root              1970-02-03 01:41 sbin
lrwxrwxrwx root     root              1970-02-03 01:41 sdcard -> /storage/emulated/legacy
-rw-r--r-- root     root          660 1970-02-03 01:41 seapp_contexts
-rw-r--r-- root     root        96188 1970-02-03 01:41 sepolicy
drwxr-x--x root     sdcard_r          1970-02-03 01:41 storage
dr-xr-xr-x root     root              1970-02-03 01:41 sys
drwxr-xr-x root     root              2014-12-28 15:18 system
lrwxrwxrwx root     root              1970-02-03 01:41 tombstones -> /data/tombstones
-rw-r--r-- root     root         8196 1970-02-03 01:41 ueventd.qcom.rc
-rw-r--r-- root     root         7275 1970-02-03 01:41 ueventd.rc
lrwxrwxrwx root     root              1970-02-03 01:41 usbdisk -> /storage/usbdisk
lrwxrwxrwx root     root              1970-02-03 01:41 vendor -> /system/vendor
root@C1905:/ #
Please add this ls format to winscp.
Test version WinSCP, Version 5.5.6 (Build 4746)
The format is way too different to any that WinSCP supports. Isn't there SFTP support on cyanogenmod?
