Topic "Duplicate Directories and Files"
coogh
Hi all,
I have to copy multiple directories and files from a EXT4 drive to a NTFS one. To do this, the standard function "duplicate" fails because there are problems with the parameter "-r".
The right command to use (tried in putty) is "cp --no-preserve=all -r -f". How can I applied it to multiple directories and files selected in the right panel, specifing the destination directory?
Thanks a lot.
What "problems" are you having with the parameter "-r"?
The system hangs and says that it's impossible to preserve attributes.
With my string, everything is just fine.
You can apply your command to all selected files/directories using custom command functionality:
http://winscp.net/eng/docs/custom_command
coogh
I tried many times to apply "cp --no-preserve=all -r -f" command to multiple directories but I can't find the right sintax.
I'm very noob, somebody can explain me how to apply this command?
Thanks a lot.
The command will vary with your specific needs. The basic syntax is like:
cp --no-preserve=all -r -f ! /target/path
