PowerShell - Session.FileTransferProgress Event - Frequency
Nebsorg
Hello !
I'm working on a script which download automatically files on a distant serveur through SSH.
For that, I'm developing a script in Powershell with WinSCP Library. Many Thanks for this nice library and all example provided on your website !
I succeed to trigger the FileTransferProgress event in my code, but as I'm downloaded big piece of software, I would like to slow down the frequency of this trigger.
Presently, it's around every second, and I would like to move to something like every 30 seconds.
Is there a way to modify the frequency of the trigger ?
Thanks for your help !
Re: PowerShell - Session.FileTransferProgress Event - Frequency
Why? You do not need to process every call you get. Just use only every 30th call.
Nebsorg
Thanks Priryl for your answer.
Yes, that what I finally done : I set a variable to make a treatment every x seconds.
However, I think it is more efficient to be able to trigger that call at a choosen rate.
But I have a workaroud, so it's ok :)
