Topic "3 New Ideas"
Big Fan
I want to start by saying thanks you WinSCP is a great program I am a big fan.Very Happy
Idea Can you add file segmentation support as me and lots of other people use WinSCP for downloading large fills from seedboxes because seedbox companies recommend it and it is a great tool (8 GB plus in not uncommon for a HD film).
Idea Also can you add auto download where WinSCP checks every X amount of minutes or hours to see if there is a new file to download and once it has downloaded it deletes the file from the server.
Idea Can you also add WinSCP to system services so it starts up in the back ground automatically.
Guest2
Yes they are good ideas can you add them
I agree good ideas
Big Fan
I forgot to say this is for SFTP
This request is tracked here:
http://winscp.net/tracker/show_bug.cgi?id=513
See https://winscp.net/eng/docs/library_example_keep_local_directory_up_to_date
How would that work?
Big Fan
Well if there is any way to get WinSCP to start automatically in the back ground so it can do what I said above without having to be started up by a user each time.
It doesn’t have to be a service there other ways to get it to start which may be better.
And thanks for the other requests.
Instead of using the loop as shown on the link above, you can run WinSCP script from a Windows Scheduler service.
See http://winscp.net/eng/docs/guide_schedule
Big Fan
Ok thanks I will have a look at this if I can get it to run in the background silently then this is perfect.
