Sync Local Files With FTP Server
AWimpyNiNjA
I'm completely new to the scripting game and I was hoping someone could help me create a script to sync local files with a remote FTP server.
I have no problem using the GUI to complete this task, I just have no idea how to create the commands in windows Task Scheduler to sync the files every night.
I started with this
/command "option batch abort" "option confirm off" "open sftp://username:password@SERVERNAME.net/" "synchronize local [C:\test[/]]" "exit"
That doesn't seem to do anything. I tried FTP instead of SFTP and still got nothing. Can someone help me out?
Thanks!
aWimpyNiNjA
Re:
It looks like using winscp.com with the /script tag is easier but with
open ftp://username:password@servername.cpmvp.net/
It still prompts for a username and password. Any ideas?
Re:
