Topic "Remote File sorting"
nkitson
I have a Linux server I access which uses long alphanumeric strings for folder and filenames. Both folders and filenames used to sort logically in both the remote folder and file panels until, I think, v5.5.6
The folder panel sorts as expected (top right in attachment) but the filename panel (shown displaying the same folders bottom right of attachment) doesn't sort as expected.
From topic 6906 this looks like a change made in v5.6.2 beta. I sympathise with the point that topic 6906 links to here but I believe that folder listings should be conventionally sorted.
Many thanks,
Nick
Description: Remote File Sorting
WinScp 5.7 build 5125
Thanks for your post.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=1293
nkitson
Thanks Martin.
nkitson
[quote="nkitson"]
Hi Martin - can you say approximately how long this option will be? I would rather not have to revert to v5.5.6 but I may need to if this is some way off.
Nick
Sorry, I do not give any dates.
nkitson
OK, fair enough, I understand.
