How to not ftp a file if the file size is <1K
petant
I am using verison 5.1.7.
The goal is to not PUT a file on an FTP server if the file is a size 0 text file which has no data.
I have found your documentation online where you state I can use the following:
"size[KMG] Matches files smaller than size. <1K "
I am not sure exactly where to put this matching code. Do I use the <1K on the PUT command?
If I don't want to PUT a file if it is less than 0K do I use <0K?
Re: How to not ftp a file if the file size is <1K
Use put * -filemask=*>1K /target/path/ to upload all files larger than 1 KB.
See https://winscp.net/eng/docs/file_mask#size_time
That does not make sense. A file cannot have a negative size (less than 0).
petant
I have tried the recommended approach but it's not working. I don't get an error. It just seems to stop.
Here is the script that I am running:
option batch abort
open "ftp://bla-bla-bla" -explicitssl -certificate="xyz"
lcd N:\Data
put 57-1-104352.txt >1K
put 57-1-104354.txt >1K
put 57-5-105442.txt >1K
put 57-8-106914.txt >1K
put 57-169-143038.txt >1K
close
