Topic "Automate copy from windows to unix"
deviprasad
hi All,
I tried coping xml files from windows to unix and i tried the below codes
getting few errors. could any one please help me out to resolve this
C:\Program Files (x86)\WinSCP>winscp.com odeeqa:xxxx@xxxxx.com
/command "option batch abort" "option confirm off" "option transfer binary" "put
C:\Users\derath\Desktop\Exatrs\job /scratch/home/odeeqa/oracle/odee_1/documaker
/hotdirectory"
Searching for host...
Connecting to host...
Authenticating...
Using username "XXXXX".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] XXXX@XXXXXX.com
batch abort
confirm off
transfer binary
C:\...\Desktop\Exatrs\job | 0 KiB | 0.0 KiB/s | binary | 0%
C:Single Job -EMAIL.xml | 15 KiB | 3.8 KiB/s | binary | 100%
Upload of file 'Single Job -EMAIL.xml' was successful, but error occurred while
setting the permissions and/or timestamp. If the problem persists, turn on 'Igno
re permission errors' option.
No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 9
When i see the target location the file is being copied but it is in Single Job -EMAIL.xio format and not in xml.
Please help me out on this . let me know if you need any more information on this.
deviprasad
the final stuff for me to change the extension from xio to xml then my work will be done.
