Topic "WinSCP Portable always logging"
stormsh
Hello there, I am not sure if this is the right forum, because I use the WinSCP Portable from portapleapps.com. Anyway the WinSCP Version itself is 5.7.1.
When I start WinSCP and open the Tools - Preferences dialog and look under logging, everything is disabled.
When I start a session and log on to a server and look under Options - Prefernces - Logging Session logging is enabled in normal mode.
When I disable it and log off and on again, it's still (or again) enabled. How do I disable it? I couldn't find anything in the .ini files. Everything is disabled there as well (Logging=0).
Is this maybe a feature and not a bug?
Thx 4 F1.
st.
We do not support WinSCP portable here.
Note that the original WinSCP is portable too:
http://winscp.net/eng/docs/portable
stormsh
I know it is. I'll have a look if the portable has the same behavior.
