error message when conneting to remote server
ereglam
when I try to log onto a friends server, the following message pops up and terminates the connection:
Die Verbindung wurde unerwartet geschlossen. Der Server sendete den Befehlsbeendigungsstatus 1.
Translation:
the conneted was terminated unexpectantly. the server sends the command end status 1.
The log shows the following content:
. WinSCP Version 3.6.8 (Build 245) (OS 5.1.2600 Service Pack 2)
. Login time: Sonntag, 12. September 2004 23:14:01
. Session name: <user>@XXX.yaog.de
. Host name: XXX.yaog.de (Port: 22)
. User name: <user> (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: /bin/bash, EOL: 0
. Local directory: <private_path>, Remote directory: /, Update: Yes, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "XXX.yaog.de"
. Connecting to 80.190.249.4 port 22
. Server version: SSH-2.0-OpenSSH_3.4p1 Debian 1:3.4p1-1.woody.3
. We claim version: SSH-2.0-WinSCP-release-3.6.8
. Host key fingerprint is:
. ssh-rsa 1024 0f:f9:c3:77:b7:89:be:85:4e:df:5d:fb:76:36:82:3b
! Using username "<user>".
. Keyboard-interactive authentication refused
. Session password prompt (<user>@XXX.yaog.de's password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
. Server sent command exit status 1
. All channels closed. Disconnecting
* (ESshFatal) Kann das SFTP nicht initialisieren. Läuft auf dem entfernten Rechner ein SFTP Server-Programm?
* Die Verbindung wurde unerwartet geschlossen. Der Server sendete den Befehlsbeendigungsstatus 1.
I set up up a key via PuTTy using the same passphrase as the accounts password, but so far I always get the same result.
My OS is WinXP, which shouldn't really make a difference.
ereglam
PS: the log was modified for access protection
Re: error message when conneting to remote server
It seems that your server has problems running instance of sftp-server for you. Check the SSH log to see why.
