Topic "CANNOT SEND FTP FILE"
nelsybelsy1
I can receive a file but I cannot send a file, nor can I drag and drop a file. Error is below
Permission denied
You do not have a sufficient permissions (access rights) to a resource, such as a file or directory, to perform the operation.
Advertisements:
You should contact the server administrator to resolve the problem.
Access rights systems differ with operating system and the file server. With the most common combination of Unix-based system and OpenSSH:
•To see a directory contents you need to have read permissions to the directory;
•To read a file you need to have read permissions to the file;
•To write a file you need to have a write permissions to the file;
•To create or delete file you need have a write permissions to the directory;
•To change file or directory permissions you need to be its owner;
•To change file modification time you need to be its owner (note that by default WinSCP updates file modification time when uploading).
