Topic "Disabling some of the Context menu item."
pmverma
I would like to disable some of the menu from the both local and remote panel.
1. Download and Delete
2. Duplicate
3. Move To...
4. Delete
5. Rename
6. Also want to disable drag&drop within for same panel, (as file/folder can be moved)
7. And also do not want to allow the delete key from the keyboard.
Here is all I have:
1. Winscp source code downloaded
2. C++ programming knowledge(beginner to intermediate)
3. MS VS2013 Community edition
4. Using Windows 7 64 bit
I want to disable above menu and build own from source.
Can anybody please tell me where to start from? Question
What do I need more to disable the menu and keyboard action? Question
Thanks in advance. Very Happy
Description: Context menu
You cannot compile WinSCP in VS. See readme.txt is WinSCP source code package.
pmverma
Well,
I downloaded XE8 trail.
And also everything according to the
readme.txt
I have also modify
build.bat
I got following error message during building.
winscp source version: 5.7.2
Windows 7 64 bit
XE8 trail version
How to continue please. Very Happy
Thanks.
OpenSSL already built
Expat already built
neon already built
All done
"D:\Winscp\source\WinSCP.groupproj" (Build target) (1) ->
"D:\Winscp\source\ScpForms.cbproj" (Build target) (13) ->
(_BCC32CoreCompile target) ->
  forms\MessageDlg.cpp(542): error E2451: Undefined symbol '_SMsgDlgWarning'
  forms\MessageDlg.cpp(542): error E2304: Reference variable '_SMsgDlgError' must be initialized
  forms\MessageDlg.cpp(543): error E2304: Reference variable '_SMsgDlgConfirm' must be initialized
  forms\MessageDlg.cpp(543): error E2040: Declaration terminated incorrectly
  forms\MessageDlg.cpp(543): error E2190: Unexpected }
  forms\MessageDlg.cpp(713): error E2451: Undefined symbol '_SMsgDlgYes' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(718): error E2451: Undefined symbol '_SMsgDlgNo' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(723): error E2451: Undefined symbol '_SMsgDlgOK' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(728): error E2451: Undefined symbol '_SMsgDlgCancel' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(733): error E2451: Undefined symbol '_SMsgDlgAbort' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(738): error E2451: Undefined symbol '_SMsgDlgRetry' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(743): error E2451: Undefined symbol '_SMsgDlgIgnore' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(756): error E2451: Undefined symbol '_SMsgDlgNoToAll' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(767): error E2451: Undefined symbol '_SMsgDlgHelp' in function _fastcall AnswerNameAndCaption(unsigned int,UnicodeString &,UnicodeString &)
  forms\MessageDlg.cpp(1178): error E2285: Could not find a match for 'Format(const wchar_t *,int,unsigned int)' in function _fastcall TMessageForm::Create(const UnicodeString &,TStrings *,TMsgDlgType,unsigned int,const TQueryButtonAlias *,unsigned int,unsigned int,TButton * *,const UnicodeString &,const UnicodeString &,const UnicodeString &,TSize)
"D:\Winscp\source\WinSCP.cbproj" (Build target) (14) ->
  windows\Tools.cpp(833): error E2451: Undefined symbol 'Vcl_Consts_SCannotOpenClipboard' in function _fastcall CopyToClipboard(UnicodeString)
  windows\Tools.cpp(833): error E2459: Delphi style classes must be constructed using operator new in function _fastcall CopyToClipboard(UnicodeString)
    7 Warning(s)
    18 Error(s)
Time Elapsed 00:02:22.73
Press any key to continue . . .
temp.log (65.01 KB) [Download]
Description: Complete Log file
I do not have XE8, so I'm not sure if you can compile WinSCP with that.
pmverma
Thank you for your reply.
I am downloading XE6 version.
I will try with that and post here.
pmverma
Hi, prikryl.
I can disable the all the Menu as I needed.
[img]Untitled.png[/img]
And last thing I want to disable the Drag&Drop as following.
1. Drag&Drop from side to side panel or from external windows explorer is allowed. This is Ok no problem.
2. But I want to disable Drag&Drop from within same panel.
For simplicity,
Is there any GLOBAL SETTING/CODE by which I can totally disable the Drag&Drop feature.
Or could you please tell me where to start to do like above listed?
Thank you in advance.
P. M. Verma
Description: After disabling menu
See TCustomDirView.DDDragOver and TCustomDriveView.DDDragOver.
pmverma
Thanks prikryl,
I made a simple changes for not accept the DD as following.
`CustomScpExplorer.cpp:FileControlDDDragEnter`
I added a `Accept = false;`.
That help me.
And really thanks for your reply.
BTW, I have uploaded to github with the original copyright and license.
https://github.com/pmverma/winscp/tree/5.7.2.1
