Topic "TransferEventArgs.Transfers is null when using WinSCP.Session.PutFiles for folders."
dotps1
Contributor
When i use the the WinSCP.Session.PutFiles() method to transfer a folder, the TransferEventArgs.Transfers property is null. It seems to work fine with a file.
$so = New-Item -TypeName WinSCP.SessionOptions
$so.HostName = 'locallhost'
$so.UserName = 'Guest'
$so.Protocol = 'Ftp'
$s = New-Item -TypeName WinSCP.Session
$s.Open($so)
$results = $s.PutFiles('C:\TempFolder', './')
PS C:\> $results
Transfers Failures IsSuccess
{}        {}            True
i would like to use the $results.FileName and $results.Destination for other things.
thanks.
https://github.com/dotps1
dotps1
Contributor
$s.Open($so)
PS C:\> $results
{}        {}            True
thanks.
UPDATE: this only happens if the folder is empty.
The TransferOperationResult.Transfers includes only files. If you "upload" an empty folder, there are no files.
It's consistent with the case the folder is not empty. The collection will include files in the folder, but not the folder itself.
