Topic "Synchronization Error in C# Console Code : 32"
whitedevil91
I encounter sync problem when a file is still opening or processing by other process in C# console application.
So the WinSCP will stop the sync process even other standby files are ready to sync and send an error exception.
Here is I wish to configure the WinSCP option that whenever there is still opening or processing file(s), synchronization WinSCP consider skip/ignore those unable sync file(s) and continue sync other standby file(s).
I found the api and tried using
session.AdditionalExecutableArguments = "option batch continue";
. It is because I saw some past posts use scripting "option batch continue" to skip those problem file(s).
In result, It happens nothing and disconnect from my FTP server.
Below I have attached my log.txt.
Does WinSCP in C# code able to make an avoid/skip those opening/processing file(s)? so that other non-related standby file(s) able continue sync.
While those error sync file(s) throws error exception after sync process finish.
Thank you.
Best regards,
whitedevil91.
log.txt (14.66 KB) Private file
Description: (none)
whitedevil91
Hi Admin,
Is all settings in Options -> Preferences in WinSCP.exe able to apply in C# Console Application?
Best Regards,
whitedevil91
No the assembly does not support option batch continue mode.
whitedevil91
So how can I skip those opening/using file(s) during Synchronization?
Do you have any alternative way to allow C# change the batch setting or allows batch operations continue despite some errors??
In WinSCP.exe, I able to ignore the error during synchronization. After that only show error.
The setting was just a tick on Tools -> Preference -> Environment -> Continue on error (advanced users)
Thank you.
The only option is to exclude the files using exclude mask.
