Topic "which ports are using to connect"
Jimmy
Hi Very Happy ,
Which port are unsing by WinSCP, because i've a viruswall with proxy and a firewall
between my computer and my web - server
The one that you specify on "Session" tab of login dialog. This is usually default port of SSH: 22.
Jimmy
Is only this port used ?
Yes.
prikryl wrote:
Yes.
Isnt so that the client is using a low port when authentication occurd and then use a port above 1023.
If so how can i change winscp to use UsePrivilegedPort = no Cool
