Looking for RETRY option in script
NBGuy
Eastern Canada
Inside a script I am using the command "option batch abort" (I have also tried "continue")
Is there an undocumented way to use RETRY? Something like: "option batch retry"
I read the WinSCP documentation and found this values --> "off|on|abort|continue"
Using WinSCP 5.7.4 on Windows Server 2008 R2 Std SP1
WinSCP Version 5.7.4 (Build 5553) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Standard)
> 2015-07-29 14:40:17.345 Script: option batch continue
< 2015-07-29 14:40:17.345 Script: batch continue
< 2015-07-29 14:40:17.345 Script: reconnecttime 120
> 2015-07-29 14:40:17.345 Script: option confirm off
< 2015-07-29 14:40:17.345 Script: confirm off
> 2015-07-29 14:40:17.345 Script: option exclude Thumbs.*
< 2015-07-29 14:40:17.345 Script: include |Thumbs.*
. 2015-07-29 14:40:17.345 FTP: FTPS: Implicit TLS/SSL; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2015-07-29 14:40:17.345 Session reuse: Yes
. 2015-07-29 14:40:17.345 TLS/SSL versions: TLSv1.0-TLSv1.2
Thank you
Hello
I have a scheduled FTPs job that has started to fail sometimes. Just sometimes. It can log in and transfer some files. Using WinSCP 574 on Win Srv 2008 R2 Std SP1
I was using "option batch abort" in my script.
I used WinSCP GUI and I was offered the "retry" option. I hit retry and it kept going.
If I use "option batch continue" all of the files will get transferred after multiple scheduled FTPs sessions.
I was wondering if "option batch retry" would help?
I have been unable to find a reason for WinSCP to drop sessions. It started within the last 6 days.
