Topic "install client cert?"
EF
Communicating over ftps with a bank - they require ftps with username and password, plus require installing a x509 cert on the client (they provide this cert). Can't find anywhere in WinSCP to install certs or assign cert for use with a specific ftp site. Is this possible?
The client certificate support is not released yet:
http://winscp.net/tracker/show_bug.cgi?id=921
ftpuser
When will this functionality be released as I see from the bug tracker it is implemented and in release 5.8
Sorry, we do not give any dates. It will take a few weeks definitely.
We can provide you a development build for testing, if you are interested.
astronaute
Hi prikryl,
Can you please give me the development build, I would like to get rid of Bitkinex Smile
Thank you !
Sent.
robertb
Is this available yet?
robertb
Have the same issue. Please help.
It was not released yet. I've sent you a dev build.
RobHeffo
May I also please request a copy of the DEV build with Certificate support. I also have a requirement for this feature.
Thanks!
Robert Heffernan
RobHeffo
Thanks!
Robert Heffernan
Sorry! Forgot to login!
Sent.
finist
Could you kindly send me a copy of the DEV build with Certificate support too?
Thanks!
Sent.
Sujeet
Hi prikryl,
We want to attach client certificate with WinSCP for file uploading because client network do not allow anything to go out without that client certificate.
Could you please help us or let us know if you have released the newer version of WinSCP which supports client certificate.
Sujeet
Please download WinSCP 5.8 beta
http://winscp.net/eng/download.php
Sujeet
Thanks prikryl.
Do you have any sample code with you for how to attach the certificate with WinSCP session.
Use SessionOptions.TlsClientCertificatePath.
The property will be documented shortly on:
http://winscp.net/eng/docs/library_sessionoptions
Sujeet
Thanks prikryl, but I am not able to find given property "TlsClientCertificatePath" with WinSCP576automation.
However is there any way to attach certificate directly as we don't have path of certificate with us, we have to pick installed cert by its name provided from machine. We do attach the same to web reference like "WebServRef.ClientCertificates.Add(cert)" where cert is the X509Certificate object.
Could you please help us for this.
Thanks.
Sujeet
Thanks.
My Bad...
Found given property in WinSCP 5.8 Beta.
Could you please help me with my another query, is there any way to pass/attach certificate by object and not by path.
No, this is not supported.
RobHeffo
Hi, I am finally getting around to trying to use this code and am getting the following error...
The code I am using to create the session options is....
I can't see what is wrong here. The TLS Client Certificate is a PPK file, the host key is copied from WinSCP
Any suggestions?[/img]
The .ppk file is not FTP TLS client client certificate, it's SSH/SFTP private key file. Use SessionOptions.SshPrivateKeyPath.
Onur
Have you published any example powershell code for this please?
Regards,
Onur
Use Generate Code function of the latest beta version:
http://winscp.net/eng/docs/ui_generateurl#code
Thanks a lot, it rocks Mr. Green
Regards,
Onur
