Topic "Powershell script from SQL Server Agent giving "'Add-Type' is not recognized" error"
DakotaPaul
I adapted the WinSCP PowerShell example to upload a file and it works perfectly from powershell.exe. I then created an SQL Server Agent job to run this script but it's failing on the try-catch block with the error: "The term 'Add-Type' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again."
In my agent job step the Type is set to PowerShell and I just pasted the script from the .ps1 file that works from the command line. This is on SQL Server 2008 R8. Has anyone seen this before?
The Add-Type is supported since PowerShell 2.0.
Maybe your SQL server supports PowerShell 1.0 only.
You can use this method instead:
[Reflection.Assembly]::LoadFrom("WinSCPnet.dll") | Out-Null
See footnote at:
http://winscp.net/eng/docs/library_powershell#fn5
DakotaPaul
That did it! Thank you so much. This makes my life much easier. Very Happy
