Corrupt uploads
as1981
Corrupt uploads
All,
I am uploading lots of jpg files using the .putfiles function.
TransferMode is set to TransferMode_Binary
Sometimes the transferResult.IsSuccess result is 'success' but the file is not complete. The source file size is smaller than the destination size.
Does anyone else have this problem or any ideas as to what I can try?
Andrew
Re: Corrupt uploads
If there's anything in the .Failures, the .IsSuccess cannot be true.
Note that the .IsSuccess is implemented as (Failures.Count == 0).
as1981
Thank you for your help. I have attached the log file. I replaced the folder name in the path and the server name.
The original file size is 1.37MB. The file is size uploaded is 0.99MB.
Andrew
  • winscplog_Nexfoto_Live_1_2_from_31-08-2015_15-00-00.txt (356.51 KB, Private file)
