Some Problems
POL
Some Problems
HI @all,
i have a problem and did not know how to resolve.
I use VB6 and have registered the WINSCP (Creating the tlb file ...)
i have a class named cSFTP:
a typical function to connect (bConnect)
a Property to get all all files (Property Get)
Connecting to the Host works fine (bConnect)
Getting all Files from SFTP works fine (Property Get oDirectoryFiles)
If i still download ALL FILES (o.bGetFile) in the loop it works fine
But if i wont download some files and skip in the loop a file it doenst work. i dont know why
i hope someone can help me
'Code From frmMain
    Dim o           As New cSFTP
    bOK = o.bConnect(Protocol_Sftp, Me.txtHost, Me.txtUser, Me.txtPW, Me.txtHKey, False, sErr)
'oFls is still class with a collection and reference to an new class for the file
Set oFls.oFiles = o.oDirectoryColFileList(Me.txtDownRDir, isNew, "")
'/// HERE IS THE PROBLEM
'/// Skipping an file, the next file will not download
    For i = 1 To oFls.nCount
'If i skip a file bgetfile (mySession.getfiles(sRemoteFileWithPath, sTargetPath, bRemoveFile).IsSuccess) returns false
        bOK = o.bGetFile(Me.txtDownRDir & "/" & oFls.oFile(i).sName, Me.txtDownLDir & oFls.oFile(i).sName, True)
    next i
'Code from Class
Dim mySessionOptions        As SessionOptions
Dim mySession               As Session
Dim myDirectoryInfo         As RemoteDirectoryInfo
Dim myFileInfo              As RemoteFileInfo
Dim myFiles                 As Collection
Const FileExtensionOK    As String = "OK"
Public Enum enmProtocol
    Protocol_Sftp = 0
    Protocol_Scp = 1
    Protocol_Ftp = 2
End Enum
Public Enum enmFileStatus
        isNew = 1
        isDownloaded
        All
End Enum
Private Sub Class_Terminate()
    If Not mySession Is Nothing Then
        mySession.dispose
    End If
    Set mySessionOptions = Nothing
    Set mySession = Nothing
    Set myDirectoryInfo = Nothing
    Set myFileInfo = Nothing
    Set myFiles = Nothing
End Sub
Property Get oSession() As Session
    Set oSession = mySession
End Property
Property Get oDirectoryFiles(Optional sPath As String = "/") As RemoteDirectoryInfo
    If myDirectoryInfo Is Nothing Then
        Set oDirectoryFiles = mySession.ListDirectory(sPath)
    End If
End Property
Property Get oDirectoryColFileList(Optional sPath As String = "/", Optional FileStatus As enmFileStatus = 1, Optional sFileExt As String = "") As Collection
On Error GoTo errHandle
    Dim oUBSFile        As cUBSFile
    Dim bDownload       As Boolean
    Set oDirectoryColFileList = New Collection
    goLog.Log = "Ermittle Remote Dateien .."
        Set myDirectoryInfo = mySession.ListDirectory(sPath)
        goLog.Log = "Ermittle Remote Dateien ..OK"
    End If
    goLog.Log = "Anzahl Remote Dateien .. " & oDirectoryColFileList.Count
    For Each myFileInfo In myDirectoryInfo.Files
        bDownload = False
        If myFileInfo.Name = "." Or _
           myFileInfo.Name = ".." Then
        Else
            If FileStatus = All Then
                bDownload = True
            ElseIf FileStatus = isDownloaded Then
                If UCase(Right(myFileInfo.Name, 2)) = UCase(FileExtensionOK) Then
                    bDownload = True
                End If
            ElseIf FileStatus = isNew Then
                If UCase(Right(myFileInfo.Name, 3)) <> UCase(FileExtensionOK) Then
                    bDownload = True
                End If
            End If
            If sFileExt <> "" Then
                If UCase(Right(myFileInfo.Name, Len(sFileExt))) <> UCase(sFileExt) Then
                    bDownload = False
                End If
            End If
            If bDownload Then
                Set oUBSFile = New cUBSFile
                With oUBSFile
                    .bIsDirectory = myFileInfo.isdirectory
                    .dtLastWriteTime = myFileInfo.lastwritetime
                    .nLen = myFileInfo.length
                    .sName = myFileInfo.Name
                End With
                oDirectoryColFileList.Add oUBSFile, "K" & oUBSFile.sName
                Set oUBSFile = Nothing
            End If
        End If
    Next
    goLog.Log = "Ermittle Remote Dateien .. abgeschlossen"
    Exit Property
errHandle:
    goLog.Log = "Fehler bei Ermittlung Remote Dateien .." & Err.Number & "." & Err.Description
    Err.Clear
End Property
Public Function bConnect(m_enmProtocol As enmProtocol, sHostName As String, _
                         sUserName As String, sPWD As String, _
                         Optional sHostKey As String = "", _
                         Optional bReConnectIfConnected As Boolean = False, _
                         Optional sErr As String = "") As Boolean
On Error GoTo err_Init
    goLog.Log = "Verbindung .."
    If mySession Is Nothing Then
        Set mySession = New Session
    Else
        If bReConnectIfConnected Then
            mySession.dispose
        End If
    End If
    Set mySessionOptions = New SessionOptions
    With mySessionOptions
        .Protocol = m_enmProtocol
        .HostName = sHostName
        .UserName = sUserName
        .Password = sPWD
        .SshHostKey = sHostKey
        '.GiveUpSecurityAndAcceptAnySshHostKey = True
    End With
    mySession.Open mySessionOptions
    bConnect = True
    goLog.Log = "Verbindung ..OK"
Exit Function
err_Init:
    goLog.Log = "Fehler beim Verbinden " & Err.Number & "." & Err.Description
    sErr = Err.Number & "-" & Err.Description
    Err.Clear
    mySession.dispose
    bConnect = False
End Function
Public Function bGetFile(sRemoteFileWithPath As String, sTargetPath As String, _
                         Optional bRemoveFile As Boolean = False, _
                         Optional bSetStatus As Boolean = True) As Boolean
    On Error GoTo err_GetFile
    goLog.Log = "Ermittlung der Remote Daten"
        bGetFile = False
    Else
        bGetFile = mySession.getfiles(sRemoteFileWithPath, sTargetPath, bRemoveFile).IsSuccess
        goLog.Log = "Lade Datei .."
        If (bGetFile And bSetStatus) And Not bRemoveFile Then
            Call bRenameFile(sRemoteFileWithPath, sRemoteFileWithPath & "." & FileExtensionOK)
        End If
    End If
    goLog.Log = "Ermittlung abgeschlossen"
    Exit Function
err_GetFile:
    goLog.Log = "Fehler bei der Ermittlung der Remote Daten " & Err.Number & "." & Err.Description
    Err.Clear
    bGetFile = False
End Function
Public Function bPutFile(sRemotePath As String, sLocalPath As String, _
                         Optional sFile As String = "*.*", _
                         Optional bSetStatus As Boolean = True, _
                         Optional sErr As String) As Boolean
    On Error GoTo err_PutFile
    Dim myTransferOptions   As New TransferOptions
    Dim transferResult      As TransferOperationResult
    Dim transfer            As TransferEventArgs
    Dim l                   As Long
    Dim bOK                 As Boolean
    goLog.Log = "Upload ... "
    If Right(sLocalPath, 1) <> "\" Then
        sLocalPath = sLocalPath & "\"
    End If
    If Right(sRemotePath, 1) <> "/" Then
        sRemotePath = sRemotePath & "/"
    End If
    bOK = gbDirExist(sLocalPath & DIRBACKUP)
    If Not bOK Then
        bOK = gbMkDir(sLocalPath & DIRBACKUP)
    End If
    myTransferOptions.TransferMode = TransferMode_Binary
        bPutFile = False
    Else
        goLog.Log = "Upload .. "
        Set transferResult = mySession.PutFiles(sLocalPath & sFile, sRemotePath, False, myTransferOptions)
        transferResult.Check
        For Each transfer In transferResult.Transfers
            bPutFile = (sLocalPath & sFile = transfer.FileName)
            If (bPutFile And bSetStatus) And Not bRemoveFile Then
                If bOK Then
                    goLog.Log = "Upload .. OK"
                    Call bReNameLocalFile(sLocalPath & sFile, sLocalPath & DIRBACKUP & sFile & "." & FileExtensionOK)
                Else
                    goLog.Log = "Upload .. Nicht OK"
                End If
            End If
        Next
    End If
    Exit Function
err_PutFile:
    goLog.Log = "Fehler bei Upload .. " & Err.Number & "." & Err.Description
    Err.Clear
    bPutFile = False
End Function
Public Function bRenameFile(sRemotePathFile As String, sRemotePathFileNew As String) As Boolean
    On Error GoTo err_Rename
    goLog.Log = "Umbenennen Remote Datei .. "
        bRenameFile = False
        goLog.Log = "Umbenennen Remote Datei .. Nicht OK (Session getrennt)"
    Else
        Call mySession.MoveFile(sRemotePathFile, sRemotePathFileNew)
        goLog.Log = "Umbenennen Remote Datei .. OK"
        bRenameFile = True
    End If
    Exit Function
err_Rename:
    goLog.Log = "Fehler beim Umbenennen .. " & Err.Number & "." & Err.Description
    Err.Clear
    bRenameFile = False
End Function
Public Function bReNameLocalFile(sPathFile As String, sPathFileNew As String) As Boolean
    goLog.Log = "Umbenennen Lokale Datei .."
    FileCopy sPathFile, sPathFileNew
    Kill sPathFile
    goLog.Log = "Umbenennen Lokale Datei .. OK"
errHandle:
    goLog.Log = "Fehler beim Umbenennen Lokale Datei .." & Err.Number & "." & Err.Description
    bReNameLocalFile = (Err.Number = 0)
    Err.Clear
End Function
Re: Some Problems
Sorry, I do not understand. How do you skip a file?
Your problem seems like a generic programming one, rather than a problem with WinSCP .NET assembly.
POL
Re: Some Problems
HI, thanks for your answer.
In the Code sample i didnt skip a file. But if i do that next in the Collection will not downloading.
        'Skipping like that
        If right(ofls.ofile(i).sname,3) <> "csv" then
         End if
    next i
[/code]
POL
Re: Some Problems
Hi
i have made an .NET Sample and the problem is the same:
Imports System
Imports WinSCP
Public Class sFTP
    Dim _mySession As Session
    Public Sub New()
        Dim RPath As String = "**"
        Dim LPath As String = "C:\tmp"
        Dim OK As Boolean = Connect("**", "**", "**", "**")
        Dim directory As RemoteDirectoryInfo = _mySession.ListDirectory(RPath)
        Dim fileinfo As RemoteFileInfo
' There a 7 files on the sftp server
' test1.csv, test2.csv, test3.csv, test4.csv, test1.txt, test2,txt, test3.txt
' At first i have to download only *.txt files
' For every txt files there a csv file
' For Each downloaded txt file i have to download the existing csv file (This is important!)
'First Step download only the text files
        For Each fileinfo In directory.Files
            If (Right(fileinfo.Name, 3) <> "csv" And fileinfo.Name <> "." And fileinfo.Name <> "..") Then
                OK = _mySession.GetFiles(RPath & "/" & fileinfo.Name.ToString, LPath & "\" & fileinfo.Name.ToString, True).IsSuccess
            End If
            'This works!
            'If (fileinfo.Name <> "." And fileinfo.Name <> "..") Then 'Right(fileinfo.Name, 3) <> "csv" And
            '    OK = _mySession.GetFiles(RPath & "/" & fileinfo.Name.ToString, LPath & "\" & fileinfo.Name.ToString, True).IsSuccess
            'End If
        Next
    End Sub
    Public Function Connect(HostName As String, User As String, Pw As String, HostKey As String) As Boolean
        Try
            Dim mySessionOptions As New SessionOptions
                .Protocol = Protocol.Sftp
                .HostName = HostName
                .UserName = User
                .Password = Pw
                .SshHostKey = HostKey
            End With
            _mySession = New Session
            _mySession.Open(mySessionOptions)
            Return True
        Catch e As Exception
            Return False
        End Try
    End Function
End Class
Hope u can help me
Re: Some Problems
I've tested your code and it works correctly.
Please upgrade to the latest version of the assembly and attach a full session log file showing the problem.
