Topic "mkdir error if already exists"
JohnZT
Hi prikryl,
I am using winSCP version (5.5.6) in scripting form.
Here is my script:
#--> This script was created by SQL <--#
# Automatically abort script on errors
option batch abort
# Connect
open ftp://blablabla/
# Command Line
cd /xxx/extract/
mkdir 201508
cd 201508
rm "XXX_201508*.zip"
put "\\blabla\201508\XXX_201508*.zip"
# Disconnect
close
# Exit WinSCP
#--> EOF This script was created by SQL <--#
And this is my xmllog:
<session xmlns="http://winscp.net/schema/session/1.0" name="blabla" start="2015-09-08T13:20:24.578Z">
  <failure>
    <message>Error creating folder '201508'.</message>
    <message>201508: File exists.</message>
  </failure>
  <mkdir>
    <filename value="/xxx/extract//201508" />
    <result success="false">
    </result>
  </mkdir>
</session>
Is there any way I confirm if the folder already exists and bypass mkdir step?
Best regards,
João Silva
You can set option batch continue before mkdir to ignore any errors and restore the option batch abort after.
Or use PowerShell script with WinSCP .NET assembly.
See also http://winscp.net/eng/docs/script_checking_file_existence
Hi again prikryl,
Thank you very much!
Best regards,
João Silva
It worked for me.
Really good solution!!!
