Topic "escape spaces in path during pscp batch copy in windows (pull file)"
Pascal
Hello
Maybe somebody have same issue in past
I would like pull a file from a windows computer wit space in path (I know that is better whitout space but I cannot change organisation for historical configuration
so, my commande is for example
below command not works, I have a message : pscp: C:\Sftpfolder\USER1\EXPORT\accountion\folder with space": Cannot create file
C:\Toolspscp.exe -sftp -v -batch -l USER1 -pw 123456 USER1@XXX.XXX.XXX.XXX:"/folder with space/filename space.xls" "C:\Sftpfolder\USER1\EXPORT\accountion\folder with space\"
below this one works (space can be use for source not for target) strange no ?
C:\Tools\pscp.exe -sftp -v -batch -l USER1 -pw 123456 USER1@XXX.XXX.XXX.XXX:"/folder with space/filename space.xls" C:\Sftpfolder\USER1\EXPORT\accountion\folderwithoutspace\
I have found lot of topic on the web but no one have solution
http://superuser.com/questions/532919/how-to-use-pscp-to-copy-file-from-unix-machine-to-windows-machine-where-target-p
I have tested with "C:\folder with space" or C:\"folder with space" or C:\folder\\ with\\ space
I have space name in source and target
some can help me ?
Thanks in advance
Pascal
version of pscp is the last one 0.65
Pascal
Sorry
I am not on the good forum Confused
I have found the good syntax now for do it
regards
