Topic "[Bug / Feature request] Make the console window a non-blocking window"
mario75
at the moment, the console window (see attachment) is a blocking window, which means you cannot access the main GUI while running a command. You even can't minimize the main window because the console window is blocking everything. I doubt that this is intentional, so I flagged this as a bug.
Please make it a non-blocking window instead.
Description: The console window I am talking about
Use Open in PuTTY command if you need a separate console window.
See http://winscp.net/eng/docs/integration_putty
