Topic "WinSCP downloads twice when using synchronize local and SCP"
Klaus_1250
When running WinSCP in batch/console mode, and using synchronize local, it always downloads files twice. One time just as file.whatever, the second time as /.../file.whatever. It is exactly the (source) same file, the only difference is the /.../.
When synchronizing for a second time and the file is unmodified, it skips it, so it is not a timestamp issue between the client and server. The problem does not occur when using sftp (v3) for transfer.
I'm using WinXP SP2 with WinSCP 3.7.1 as a client, and FreeBSD 4.10 with OpenSSH3.9p as a server. Connection is made through SSH2 (AES encryption, SCP2 transfer).
Thanks for info. However I believe that the file is actually downloaded once. It is just wrongly printed twice on the screen. I'll fix it in the next release.
mak
Synchrozie local work very slow in WinSCP.
I think it even overwrite thoses file in local that are not changed.
please check this issue.
Do you mean that it is slower then "synchronize remote"?
Please read F.A.Q.
mak
yes.
I think this is because of the way unix and windows deals with timestamps of files. I noticed that WinSCP also overwrites those files which have not been modified. (there is free software SyncBack, it is able to deal with this problem but unfortunately SyncBack does not support SFTP protocol, which WinSCP supports, I wish WinSCP and SyncBack could combine their good features)
mak wrote:
yes.
So it is not slower, it just downloads more files that it should, am I right? That's what the link I've posted the last time should help you to avoid.
mak
Yes it downloads more files. But where is the link you posted last time. On this Forum Page I did not find any link.
A more issue is that WinSCP could not deal with temporay files created by MS office (e.g ~wrl00359.tmp) , (I think these are not files but link to other files). Also Thumbs.db files (these files created by Windows for thumbnail view of files.) can not be copied by WinSCP. Beacuase each time WinSCP encounters these these files it aks for (skip, abort, retry) therefore it takes too much time to press button to proceed these message. Either these should be copied or there should be option (skip all) to skip all theses file.
Here:
prikryl wrote:
Please read F.A.Q.
That's probably because the files are locked by the office, so they cannot be read by other application. I'll check it.
