Topic "Run winmerge via Apply command"
techie
Can't run winmerge with this command - winmerge just doesn't start. Without "start" prefix winmerge starts, but it unable to find temporary file.
═════════════════════════ Apply command ═══════════════════════════
 Enter command to process selected files
 start /wait winmerge ! !^!
 Patterns: !! - exclamation mark; ! - file name
 !?prompt?default! - prompts user for parameter value
 !& - selected files list (quoted, space-delimited)
 Local command patterns: !^! - file name from local panel
 ( ) Remote command           (x) Local command
 [ ] Apply to directories     [ ] Execute recursively
 [ ] Show results in console
                         [ Ok ]  [ Cancel ]
I'm not quite sure what are you tring to achieve. But in case you do: "start" is not a program, it is internal command of Window shell (cmd.exe). So you must run cmd.exe to interpret it. You do it like this:
cmd.exe /c start /wait winmerge ! !^!
Lorand
I successfull started Winmerge with this command:
"C:\Program Files\WinMerge\WinMergeU.exe" "!^!" "!" (Local Command)
But after i save the modifications in remote file and close the WinMerge i lose the modifications.
Why?
This request is being tracked already.
