Out of memory error on VMS
Similar to the problem on the IBM zOS, I'm having a problem connecting to a VMS host running Multinet 4.4. I get the same error.
Log file using sftp:
. WinSCP Version 3.7.1 (Build 257) (OS 5.0.2195 Service Pack 4)
. Login time: Wednesday, March 02, 2005 12:20:00 PM
. Session name: CHCS
. Host name: <snipped> (Port: 22)
. User name: ss_noland (Password: No, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "<snipped>"
. Connecting to <snipped) port 22
. Server version: SSH-2.0-3.2.0 F-SECURE SSH - Process Software MultiNet
. We claim version: SSH-2.0-WinSCP-release-3.7.1
. Host key fingerprint is:
. ssh-dss 1024 8d:78:b4:2b:82:69:a2:e7:bd:9e:b2:cd:cc:c0:10:f9
. Initialised HMAC-SHA1 client->server MAC algorithm
. Initialised HMAC-SHA1 server->client MAC algorithm
! Using username "ss_noland".
<snipped>
. Pageant is running. Requesting keys.
. Pageant has 0 SSH2 keys
. Session password prompt (ss_noland@<snipped>'s password: )
. Asking user for password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 267, Number: -1
. SFTP version 4 negotiated.
. Unknown server extension TRANSLATE_VMS@PROCESS.COM=7
. Unknown server extension SRI_ON_ODS5@PROCESS.COM=FALSE
. Server requests EOL sequence 0x0D0A.
. Unknown server extension OVMS@PROCESS.COM=1.2
. Unknown server extension fs-roots@process.com=....
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< Type: SSH_FXP_STATUS, Size: 89, Number: 200
< Status/error code: 8
. Server does not recognise WinSCP.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< Type: SSH_FXP_NAME, Size: 34, Number: 528
. Real path is '/disk$log/noland'
. Listing directory "/disk$log/noland".
> Type: SSH_FXP_OPENDIR, Size: 25, Number: 779
< Type: SSH_FXP_HANDLE, Size: 17, Number: 779
> Type: SSH_FXP_READDIR, Size: 17, Number: 1036
< Type: SSH_FXP_NAME, Size: 8577, Number: 1036
> Type: SSH_FXP_READDIR, Size: 17, Number: 1292
> Type: SSH_FXP_CLOSE, Size: 17, Number: 1540
< Type: SSH_FXP_NAME, Size: 4359, Number: 1292
< Type: SSH_FXP_STATUS, Size: 21, Number: 1540
< Status/error code: 0
* (ECommand) Error listing directory '/disk$log/noland'.
* Out of memory
. Startup conversation with host finished.
. Closing connection.
If I use SCP I get the following:
. Login time: Wednesday, March 02, 2005 12:25:13 PM
. Host name: <snipped) (Port: 22)
. Transfer Protocol: SCP
. Proxy: none
. Connecting to 143.83.107.87 port 22
<snipped>
. Sent password
. Access granted
. Using SCP protocol.
> echo "WinSCP: this is end-of-file:0"
<snipped>
. Waiting for data timed out, asking user what to do.
. Asking user:
. Host has not answered for 15 seconds.
. Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. Data has arrived, closing query to user.
Username: echo "WinSCP: this is end-of-file:0"
. Server sent command exit status 0
. All channels closed. Disconnecting
< Error reading command input
* (ESshFatal) Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
* Connection has been unexpectedly closed. Server sent command exit status 0.
Thanks for the help.
Thanks.
. Login time: Thursday, March 03, 2005 11:16:46 AM
. Proxy: none
. Connecting to <snipped> port 22
<snipped>
. Pageant has 1 SSH2 keys
. Trying Pageant key #0
. Key refused
. Sent password
. Access granted
> 01,00,00,00,05,
< 02,00,00,00,04,00,00,00,19,54,52,41,4E,53,4C,41,54,45,5F,56,4D,53,40,50,52,
< 4F,43,45,53,53,2E,43,4F,4D,00,00,00,01,37,00,00,00,17,53,52,49,5F,4F,4E,5F,
< 4F,44,53,35,40,50,52,4F,43,45,53,53,2E,43,4F,4D,00,00,00,05,46,41,4C,53,45,
< 00,00,00,07,6E,65,77,6C,69,6E,65,00,00,00,02,0D,0A,00,00,00,10,4F,56,4D,53,
< 40,50,52,4F,43,45,53,53,2E,43,4F,4D,00,00,00,03,31,2E,32,00,00,00,19,54,52,
< 41,4E,53,4C,41,54,45,5F,56,4D,53,40,50,52,4F,43,45,53,53,2E,43,4F,4D,00,00,
< 00,01,37,00,00,00,14,66,73,2D,72,6F,6F,74,73,40,70,72,6F,63,65,73,73,2E,63,
< 6F,6D,00,00,00,56,00,00,00,0B,44,49,53,4B,24,53,59,53,54,45,4D,02,00,00,00,
< 08,44,49,53,4B,24,4C,4F,47,02,00,00,00,0C,44,49,53,4B,24,4A,4F,55,52,4E,41,
< 4C,02,00,00,00,0F,44,49,53,4B,24,50,41,47,45,53,57,41,50,5F,41,02,00,00,00,
< 0F,44,49,53,4B,24,50,41,47,45,53,57,41,50,5F,42,02,
> C8,00,00,00,C8,00,00,00,1D,77,69,6E,73,63,70,40,77,69,6E,73,63,70,2E,73,6F,
> 75,72,63,65,66,6F,72,67,65,2E,6E,65,74,
< 65,00,00,00,C8,00,00,00,08,00,00,00,46,65,78,74,65,6E,64,65,64,20,72,65,71,
< 75,65,73,74,20,74,79,70,65,20,60,60,77,69,6E,73,63,70,40,77,69,6E,73,63,70,
< 2E,73,6F,75,72,63,65,66,6F,72,67,65,2E,6E,65,74,27,27,20,6E,6F,74,20,73,75,
< 70,70,6F,72,74,65,64,2E,00,00,00,02,65,6E,
> 10,00,00,02,10,00,00,00,01,2E,
< 68,00,00,02,10,00,00,00,01,00,00,00,10,2F,64,69,73,6B,24,6C,6F,67,2F,6E,6F,
< 6C,61,6E,64,00,00,00,00,02,
> 0B,00,00,03,0B,00,00,00,10,2F,64,69,73,6B,24,6C,6F,67,2F,6E,6F,6C,61,6E,64,
< 66,00,00,03,0B,00,00,00,08,00,37,5E,E8,00,41,BB,30,
> 0C,00,00,04,0C,00,00,00,08,00,37,5E,E8,00,41,BB,30,
< Type: SSH_FXP_NAME, Size: 8579, Number: 1036
< 68,00,00,04,0C,00,00,00,64,00,00,00,0D,2E,6E,65,77,6D,61,69,6C,62,6F,78,65,
< 73,00,00,00,BF,01,00,00,00,00,00,00,00,00,00,00,00,09,53,53,5F,4E,4F,4C,41,
< 4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,D2,E2,6D,00,00,00,
< 00,40,D2,E2,4C,00,00,00,00,40,D2,E2,6D,00,00,00,0C,32,30,32,31,31,65,30,30,
< 2E,74,6D,70,00,00,00,BF,01,00,00,00,00,00,00,00,4C,00,00,00,09,53,53,5F,4E,
< 4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,BE,F0,0B,
< 00,00,00,00,40,BE,F0,0B,00,00,00,00,40,BE,F0,0B,00,00,00,0C,32,30,32,37,34,
< 36,32,34,2E,74,6D,70,00,00,00,BF,01,00,00,00,00,00,00,00,4C,00,00,00,09,53,
< 53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,41,
< 7F,8A,F1,00,00,00,00,41,7F,8A,F1,00,00,00,00,41,7F,8A,F1,00,00,00,0C,32,30,
< 32,38,38,61,33,62,2E,74,6D,70,00,00,00,BF,01,00,00,00,00,00,00,00,4C,00,00,
< 00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,
< 00,00,41,82,A2,31,00,00,00,00,41,82,A2,31,00,00,00,00,41,82,A2,31,00,00,00,
< 0C,32,30,33,39,37,64,66,63,2E,74,6D,70,00,00,00,BF,01,00,00,00,00,00,00,00,
< 4C,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,
< E8,00,00,00,00,41,63,EF,64,00,00,00,00,41,63,EF,64,00,00,00,00,41,63,EF,64,
< 00,00,00,0A,32,32,6A,75,6C,2E,64,69,61,67,00,00,00,BF,01,00,00,00,00,00,00,
< 40,65,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,
< 81,E8,00,00,00,00,3F,1D,4E,CF,00,00,00,00,3F,1D,4E,CF,00,00,00,00,3F,1D,4E,
< CF,00,00,00,0A,34,2D,61,75,67,2E,64,69,61,67,00,00,00,BF,01,00,00,00,00,00,
< 00,C6,98,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,
< 00,81,E8,00,00,00,00,41,11,0D,10,00,00,00,00,41,11,0D,10,00,00,00,00,41,11,
< 0D,10,00,00,00,0B,34,2D,66,65,62,2D,32,30,30,34,2E,00,00,00,BF,01,00,00,00,
< 00,00,06,F2,5E,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,E8,00,00,00,00,40,1F,9B,3D,00,00,00,00,40,1F,9B,38,00,00,00,00,
< 40,1F,9B,3D,00,00,00,11,34,2D,66,65,62,2D,65,76,61,6E,61,63,2E,64,69,61,67,
< 00,00,00,BF,01,00,00,00,00,00,06,EE,99,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,
< 44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,1F,A8,51,00,00,00,00,
< 40,1F,A8,4C,00,00,00,00,40,1F,A8,51,00,00,00,0B,61,66,61,64,75,6D,70,2E,74,
< 78,74,00,00,00,BF,01,00,00,00,00,00,00,35,51,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,41,D1,84,6E,00,00,
< 00,00,41,D1,80,23,00,00,00,00,41,D1,84,6E,00,00,00,08,61,75,74,68,2E,74,78,
< 74,00,00,00,BF,01,00,00,00,00,00,02,F8,B0,00,00,00,09,53,53,5F,4E,4F,4C,41,
< 4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,41,A3,15,97,00,00,00,
< 00,41,A3,15,95,00,00,00,00,41,A3,15,97,00,00,00,0F,62,61,63,6B,75,70,63,68,
< 65,63,6B,2E,63,6F,6D,00,00,00,BF,01,00,00,00,00,00,00,00,CE,00,00,00,09,53,
< 53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,3E,
< 81,AA,6F,00,00,00,00,3E,23,D3,75,00,00,00,00,3E,81,AA,6F,00,00,00,08,62,75,
< 63,6B,2E,63,61,70,00,00,00,BF,01,00,00,00,00,00,56,7F,00,00,00,00,09,53,53,
< 5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,41,F8,
< B4,AD,00,00,00,00,41,F8,A9,46,00,00,00,00,41,F8,B4,AD,00,00,00,0C,62,75,63,
< 6B,64,75,6D,70,2E,74,78,74,00,00,00,BF,01,00,00,00,00,00,00,3B,02,00,00,00,
< 09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,
< 00,41,D1,84,80,00,00,00,00,41,D1,80,20,00,00,00,00,41,D1,84,80,00,00,00,09,
< 63,68,64,69,72,2E,63,6F,6D,00,00,00,BF,01,00,00,00,00,00,00,01,A0,00,00,00,
< 00,41,A3,58,F2,00,00,00,00,41,A3,58,F2,00,00,00,00,41,A3,58,F2,00,00,00,0C,
< 63,6C,69,65,6E,74,69,70,2E,74,78,74,00,00,00,BF,01,00,00,00,00,00,00,14,0A,
< 00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,
< 00,00,00,00,40,44,56,27,00,00,00,00,3F,FC,2D,55,00,00,00,00,40,44,56,27,00,
< 00,00,0F,63,6F,6E,74,72,6F,6C,6C,65,72,2E,64,69,61,67,00,00,00,BF,01,00,00,
< 00,00,00,00,D4,FF,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,
< 49,43,00,00,81,E8,00,00,00,00,41,17,67,12,00,00,00,00,41,17,67,11,00,00,00,
< 00,41,17,67,12,00,00,00,0D,63,6F,75,6E,74,5F,64,73,6D,2E,63,6F,6D,00,00,00,
< BF,01,00,00,00,00,00,00,13,DE,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,E8,00,00,00,00,41,6D,56,3C,00,00,00,00,41,6D,56,
< 3C,00,00,00,00,41,6D,56,3C,00,00,00,0D,63,70,75,5F,65,72,72,73,2E,64,69,61,
< 67,00,00,00,BF,01,00,00,00,00,00,00,48,B6,00,00,00,09,53,53,5F,4E,4F,4C,41,
< 4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,41,08,D7,19,00,00,00,
< 00,41,08,D7,19,00,00,00,00,41,08,D7,19,00,00,00,07,64,63,6C,74,69,70,73,00,
< 00,00,BF,02,00,00,00,00,00,00,12,00,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,
< 00,00,00,04,53,41,49,43,00,00,41,E9,00,00,00,00,40,96,30,A7,00,00,00,00,40,
< 96,30,87,00,00,00,00,40,96,30,A7,00,00,00,0F,64,63,6C,5F,73,65,73,73,69,6F,
< 6E,2E,6C,6F,67,00,00,00,BF,01,00,00,00,00,00,00,1F,E0,00,00,00,09,53,53,5F,
< 4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,42,23,1D,
< 7D,00,00,00,00,42,23,1D,5F,00,00,00,00,42,23,1D,7D,00,00,00,0A,64,69,73,74,
< 72,6F,2E,64,69,73,00,00,00,BF,01,00,00,00,00,00,00,00,32,00,00,00,09,53,53,
< 5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,8F,
< D9,7F,00,00,00,00,40,8F,D9,7F,00,00,00,00,40,8F,D9,7F,00,00,00,0A,64,73,6D,
< 6D,67,72,2E,6C,69,73,00,00,00,BF,01,00,00,00,00,00,00,30,DA,00,00,00,09,53,
< 53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,
< 36,25,74,00,00,00,00,40,36,25,5C,00,00,00,00,40,36,25,74,00,00,00,0C,65,74,
< 68,65,72,65,61,6C,2E,74,78,74,00,00,00,BF,01,00,00,00,00,00,00,34,70,00,00,
< 00,00,40,E1,56,B5,00,00,00,00,40,E1,54,D6,00,00,00,00,40,E1,56,B5,00,00,00,
< 14,65,76,61,6E,61,61,5F,63,6F,75,6E,74,5F,64,73,6D,2E,74,78,74,00,00,00,BF,
< 01,00,00,00,00,00,00,40,EE,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,
< 04,53,41,49,43,00,00,81,E8,00,00,00,00,41,6D,56,82,00,00,00,00,41,6D,56,42,
< 00,00,00,00,41,6D,56,82,00,00,00,18,65,76,61,6E,61,61,5F,68,6F,73,6D,67,72,
< 5F,73,74,61,74,75,73,2E,74,78,74,00,00,00,BF,01,00,00,00,00,00,00,FC,4E,00,
< 00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,FF,00,
< 00,00,00,41,6D,56,74,00,00,00,00,41,6D,56,5C,00,00,00,00,41,6D,56,74,00,00,
< 00,09,65,76,61,6E,73,2E,63,61,70,00,00,00,BF,01,00,00,00,00,00,A5,7C,D5,00,
< 00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,
< 00,00,00,41,F8,B4,C1,00,00,00,00,41,F8,A9,48,00,00,00,00,41,F8,B4,C1,00,00,
< 00,08,66,69,6C,65,2E,6C,69,73,00,00,00,BF,01,00,00,00,00,00,00,01,8C,00,00,
< 00,00,42,23,34,64,00,00,00,00,42,23,34,64,00,00,00,00,42,23,34,64,00,00,00,
< 1B,66,6D,67,5F,6C,6F,63,61,6C,5F,70,61,72,61,6D,5F,6C,69,62,72,61,72,79,2E,
< 6B,6E,6C,00,00,00,BF,01,00,00,00,00,00,00,C8,60,00,00,00,09,53,53,5F,4E,4F,
< 4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,A0,00,00,00,00,42,25,A0,DF,00,
< 00,00,00,3F,1D,4E,81,00,00,00,00,42,25,A0,DF,00,00,00,0E,66,74,70,5F,73,65,
< 72,76,65,72,2E,6C,6F,67,00,00,00,BF,01,00,00,00,00,00,00,04,C2,00,00,00,09,
< 53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,
< 42,25,C6,34,00,00,00,00,42,25,C5,15,00,00,00,00,42,25,C6,34,00,00,00,0B,67,
< 65,74,6E,6F,64,65,2E,63,6F,6D,00,00,00,BF,01,00,00,00,00,00,00,01,36,00,00,
< 00,00,3E,A9,26,67,00,00,00,00,3E,A9,26,67,00,00,00,00,3E,A9,26,67,00,00,00,
< 11,67,65,74,5F,63,6C,69,65,6E,74,5F,69,70,2E,63,6F,6D,00,00,00,BF,01,00,00,
< 00,00,00,00,00,B4,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,
< 49,43,00,00,81,E8,00,00,00,00,3F,FC,2D,2E,00,00,00,00,3F,FC,2C,5B,00,00,00,
< 00,3F,FC,2D,2E,00,00,00,07,68,6F,73,74,6C,6F,67,00,00,00,BF,02,00,00,00,00,
< 00,00,5A,00,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,
< 00,00,41,E9,00,00,00,00,42,25,AE,C2,00,00,00,00,3B,1F,82,BF,00,00,00,00,42,
< 25,AE,C2,00,00,00,0F,6A,6F,75,72,6E,61,6C,64,69,73,6B,2E,63,6F,6D,00,00,00,
< BF,01,00,00,00,00,00,00,02,30,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,E8,00,00,00,00,42,23,40,85,00,00,00,00,42,23,40,
< 85,00,00,00,00,42,23,40,85,00,00,00,0F,6A,6F,75,72,6E,61,6C,64,69,73,6B,2E,
< 6C,6F,67,00,00,00,BF,01,00,00,00,00,00,00,02,00,00,00,00,09,53,53,5F,4E,4F,
< 4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,42,26,EE,54,00,
< 00,00,00,42,26,EE,53,00,00,00,00,42,26,EE,54,00,00,00,10,6A,6F,75,72,6E,61,
< 6C,5F,64,69,73,6B,2E,74,78,74,00,00,00,BF,01,00,00,00,00,00,00,6E,72,00,00,
< 00,00,42,26,EE,53,00,00,00,00,42,23,4E,10,00,00,00,00,42,26,EE,53,00,00,00,
< 0D,6B,65,65,70,66,6F,72,61,77,68,69,6C,65,00,00,00,BF,02,00,00,00,00,00,00,
< 02,00,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,
< 41,E9,00,00,00,00,40,9F,62,F9,00,00,00,00,3D,99,BE,7B,00,00,00,00,40,9F,62,
< F9,00,00,00,0F,6B,69,6C,6C,5F,71,75,65,75,65,73,2E,63,6F,6D,00,00,00,BF,01,
< 00,00,00,00,00,00,03,02,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,
< 53,41,49,43,00,00,81,E8,00,00,00,00,41,A3,21,CD,00,00,00,00,41,A3,21,CC,00,
< 00,00,00,41,A3,21,CD,00,00,00,0F,6C,69,73,74,5F,71,75,65,75,65,73,2E,63,6F,
< 6D,00,00,00,BF,01,00,00,00,00,00,00,01,E0,00,00,00,09,53,53,5F,4E,4F,4C,41,
< 4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,72,8F,D7,00,00,00,
< 00,40,72,8F,D7,00,00,00,00,40,72,8F,D7,00,00,00,09,6C,6F,67,69,6E,2E,63,6F,
< 6D,00,00,00,BF,01,00,00,00,00,00,00,10,20,00,00,00,09,53,53,5F,4E,4F,4C,41,
< 4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,41,C6,96,82,00,00,00,
< 00,41,C6,96,82,00,00,00,00,41,C6,96,82,00,00,00,04,6C,70,72,2E,00,00,00,BF,
< 01,00,00,00,00,00,00,05,AC,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,
< 04,53,41,49,43,00,00,81,E8,00,00,00,00,40,3C,CA,F2,00,00,00,00,40,3C,CA,F2,
< 00,00,00,00,40,3C,CA,F2,00,00,00,19,6D,61,69,6C,24,30,30,30,31,31,38,61,63,
< 30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,21,EE,
< 00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,
< 00,00,00,00,42,21,38,08,00,00,00,00,42,21,38,08,00,00,00,00,42,21,38,08,00,
< 00,00,19,6D,61,69,6C,24,30,30,30,39,35,39,33,38,30,30,30,35,30,30,61,34,2E,
< 6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,0D,26,00,00,00,09,53,53,5F,4E,4F,
< 4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,21,45,E1,00,
< 00,00,00,42,21,45,E1,00,00,00,00,42,21,45,E1,00,00,00,19,6D,61,69,6C,24,30,
< 30,30,39,35,39,61,33,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,
< 00,00,00,00,00,0D,8E,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,
< 41,49,43,00,00,81,80,00,00,00,00,42,21,45,E1,00,00,00,00,42,21,45,E1,00,00,
< 00,00,42,21,45,E1,00,00,00,19,6D,61,69,6C,24,30,30,30,39,35,62,35,66,30,30,
< 30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,0D,8E,00,00,
< 00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,
< 00,00,42,21,45,E4,00,00,00,00,42,21,45,E4,00,00,00,00,42,21,45,E4,00,00,00,
< 19,6D,61,69,6C,24,30,30,30,39,35,62,38,37,30,30,30,35,30,30,61,34,2E,6D,61,
< 69,00,00,00,BF,01,00,00,00,00,00,00,0D,8E,00,00,00,09,53,53,5F,4E,4F,4C,41,
< 4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,21,45,E5,00,00,00,
< 00,42,21,45,E5,00,00,00,00,42,21,45,E5,00,00,00,19,6D,61,69,6C,24,30,30,63,
< 31,63,34,63,30,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,
< 00,00,00,10,6E,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,22,7B,49,00,00,00,00,42,22,7B,49,00,00,00,00,
< 42,22,7B,49,00,00,00,19,6D,61,69,6C,24,30,30,63,61,34,38,30,30,30,30,30,35,
< 30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,21,EE,00,00,00,09,
< 53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,
< 42,22,89,91,00,00,00,00,42,22,89,91,00,00,00,00,42,22,89,91,00,00,00,19,6D,
< 61,69,6C,24,30,30,63,61,35,61,61,38,30,30,30,35,30,30,61,34,2E,6D,61,69,00,
< 00,00,BF,01,00,00,00,00,00,00,06,0A,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,
< 00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,22,89,B0,00,00,00,00,42,
< 22,89,B0,00,00,00,00,42,22,89,B0,00,00,00,19,6D,61,69,6C,24,30,30,64,32,38,
< 38,38,39,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,
< 00,10,28,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,
< 00,81,80,00,00,00,00,42,22,97,69,00,00,00,00,42,22,97,69,00,00,00,00,42,22,
< 97,69,00,00,00,19,6D,61,69,6C,24,30,30,64,32,38,39,39,37,30,30,30,35,30,30,
< 61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,10,AA,00,00,00,09,53,53,
< 5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,22,
< 97,6B,00,00,00,00,42,22,97,6B,00,00,00,00,42,22,97,6B,00,00,00,19,6D,61,69,
< 6C,24,30,30,64,32,38,62,62,33,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,
< BF,01,00,00,00,00,00,00,10,AA,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,22,97,6E,00,00,00,00,42,22,97,
< 6E,00,00,00,00,42,22,97,6E,00,00,00,19,6D,61,69,6C,24,30,30,64,32,38,62,66,
< 61,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,10,
< AA,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,
< 80,00,00,00,00,42,22,97,6F,00,00,00,00,42,22,97,6F,00,00,00,00,42,22,97,6F,
< 00,00,00,19,6D,61,69,6C,24,30,30,66,62,36,39,30,39,30,30,30,35,30,30,61,34,
< 2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,10,28,00,00,00,09,53,53,5F,4E,
< 4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,22,DB,FD,
< 00,00,00,00,42,22,DB,FD,00,00,00,00,42,22,DB,FD,00,00,00,19,6D,61,69,6C,24,
< 30,30,66,62,61,66,37,62,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,
< 00,00,00,00,00,00,10,AA,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,
< 53,41,49,43,00,00,81,80,00,00,00,00,42,22,DC,74,00,00,00,00,42,22,DC,74,00,
< 00,00,00,42,22,DC,74,00,00,00,19,6D,61,69,6C,24,30,31,31,33,39,36,65,30,30,
< 30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,0E,5E,00,
< 00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,
< 00,00,00,42,23,04,8E,00,00,00,00,42,23,04,8E,00,00,00,00,42,23,04,8E,00,00,
< 00,19,6D,61,69,6C,24,30,31,31,36,62,39,64,63,30,30,30,35,30,30,61,34,2E,6D,
< 61,69,00,00,00,BF,01,00,00,00,00,00,00,14,BA,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,23,09,D2,00,00,
< 00,00,42,23,09,D1,00,00,00,00,42,23,09,D2,00,00,00,19,6D,61,69,6C,24,30,31,
< 31,61,33,62,61,66,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,
< 00,00,00,00,11,8C,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,
< 49,43,00,00,81,80,00,00,00,00,42,23,0F,B4,00,00,00,00,42,23,0F,B4,00,00,00,
< 00,42,23,0F,B4,00,00,00,19,6D,61,69,6C,24,30,31,38,61,66,34,66,66,30,30,30,
< 35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,13,7E,00,00,00,
< 09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,
< 00,42,23,CC,D2,00,00,00,00,42,23,CC,D2,00,00,00,00,42,23,CC,D2,00,00,00,19,
< 6D,61,69,6C,24,30,31,39,33,37,35,62,65,30,30,30,35,30,30,61,34,2E,6D,61,69,
< 00,00,00,BF,01,00,00,00,00,00,00,23,1A,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,
< 44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,23,DB,16,00,00,00,00,
< 42,23,DB,16,00,00,00,00,42,23,DB,16,00,00,00,19,6D,61,69,6C,24,30,31,39,33,
< 38,33,36,64,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,
< 00,00,06,98,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,
< 00,00,81,80,00,00,00,00,42,23,DB,2D,00,00,00,00,42,23,DB,2D,00,00,00,00,42,
< 23,DB,2D,00,00,00,19,6D,61,69,6C,24,30,31,39,62,63,65,30,64,30,30,30,35,30,
< 30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,13,2A,00,00,00,09,53,
< 53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,
< 23,E9,16,00,00,00,00,42,23,E9,16,00,00,00,00,42,23,E9,16,00,00,00,19,6D,61,
< 69,6C,24,30,31,39,62,64,30,31,64,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,
< 00,BF,01,00,00,00,00,00,00,13,C6,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,
< 00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,23,E9,1A,00,00,00,00,42,23,
< E9,1A,00,00,00,00,42,23,E9,1A,00,00,00,19,6D,61,69,6C,24,30,31,39,62,64,32,
< 37,64,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,
< 13,C6,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,
< 81,80,00,00,00,00,42,23,E9,1E,00,00,00,00,42,23,E9,1E,00,00,00,00,42,23,E9,
< 1E,00,00,00,19,6D,61,69,6C,24,30,31,39,62,64,33,32,38,30,30,30,35,30,30,61,
< 34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,13,C6,00,00,00,09,53,53,5F,
< 4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,23,E9,
< 1F,00,00,00,00,42,23,E9,1F,00,00,00,00,42,23,E9,1F,00,00,00,19,6D,61,69,6C,
< 24,30,31,39,62,64,34,39,64,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,
< 01,00,00,00,00,00,00,17,E6,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,
< 04,53,41,49,43,00,00,81,80,00,00,00,00,42,23,E9,21,00,00,00,00,42,23,E9,21,
< 00,00,00,00,42,23,E9,21,00,00,00,19,6D,61,69,6C,24,30,31,63,33,36,38,38,33,
< 30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,13,2A,
< 00,00,00,00,42,24,2B,88,00,00,00,00,42,24,2B,88,00,00,00,00,42,24,2B,88,00,
< 00,00,19,6D,61,69,6C,24,30,31,63,33,65,66,65,61,30,30,30,35,30,30,61,34,2E,
< 6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,13,2A,00,00,00,09,53,53,5F,4E,4F,
< 4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,24,2C,6B,00,
< 00,00,00,42,24,2C,6B,00,00,00,00,42,24,2C,6B,00,00,00,19,6D,61,69,6C,24,30,
< 31,63,34,36,33,31,34,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,
< 00,00,00,00,00,12,CA,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,
< 41,49,43,00,00,81,80,00,00,00,00,42,24,2D,2C,00,00,00,00,42,24,2D,2C,00,00,
< 00,00,42,24,2D,2C,00,00,00,19,6D,61,69,6C,24,30,31,63,34,36,36,64,34,30,30,
< 30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,16,EA,00,00,
< 00,00,42,24,2D,33,00,00,00,00,42,24,2D,33,00,00,00,00,42,24,2D,33,00,00,00,
< 19,6D,61,69,6C,24,30,31,63,37,32,63,31,62,30,30,30,35,30,30,61,34,2E,6D,61,
< 69,00,00,00,BF,01,00,00,00,00,00,00,12,CA,00,00,00,09,53,53,5F,4E,4F,4C,41,
< 4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,24,31,D9,00,00,00,
< 00,42,24,31,D9,00,00,00,00,42,24,31,D9,00,00,00,19,6D,61,69,6C,24,30,31,63,
< 37,32,64,34,30,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,
< 00,00,00,16,EA,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,24,31,DB,00,00,00,00,42,24,31,DB,00,00,00,00,
< 42,24,31,DB,00,00,00,19,6D,61,69,6C,24,30,31,63,37,36,33,62,37,30,30,30,35,
< 30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,12,CA,00,00,00,09,
< 42,24,32,36,00,00,00,00,42,24,32,36,00,00,00,00,42,24,32,36,00,00,00,19,6D,
< 61,69,6C,24,30,31,63,37,36,34,35,65,30,30,30,35,30,30,61,34,2E,6D,61,69,00,
< 00,00,BF,01,00,00,00,00,00,00,16,EA,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,
< 00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,24,32,37,00,00,00,00,42,
< 24,32,37,00,00,00,00,42,24,32,37,00,00,00,19,6D,61,69,6C,24,30,32,35,63,61,
< 30,34,38,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,
< 00,23,F4,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,
< 00,81,80,00,00,00,00,42,25,2C,97,00,00,00,00,42,25,2C,97,00,00,00,00,42,25,
< 2C,97,00,00,00,19,6D,61,69,6C,24,30,33,32,35,63,62,66,30,30,30,30,35,30,30,
< 61,34,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,00,24,4C,00,00,00,09,53,53,
< 5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,26,
< 7E,19,00,00,00,00,42,26,7E,19,00,00,00,00,42,26,7E,19,00,00,00,19,6D,61,69,
< 6C,24,30,33,32,35,65,65,30,38,30,30,30,35,30,30,61,34,2E,6D,61,69,00,00,00,
< BF,01,00,00,00,00,00,00,06,02,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,26,7E,52,00,00,00,00,42,26,7E,
< 52,00,00,00,00,42,26,7E,52,00,00,00,18,6D,61,69,6C,45,44,45,46,31,38,45,31,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,24,04,
< 00,00,00,00,42,02,E6,E5,00,00,00,00,42,02,E6,E5,00,00,00,00,42,02,E6,E5,00,
< 00,00,18,6D,61,69,6C,45,45,42,38,33,36,31,32,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,24,2A,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,04,38,4F,00,00,
< 00,00,42,04,38,4F,00,00,00,00,42,04,38,4F,00,00,00,18,6D,61,69,6C,45,46,38,
< 31,35,33,34,36,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,24,2A,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,05,89,B9,00,00,00,00,42,05,89,B9,00,00,00,00,
< 42,05,89,B9,00,00,00,18,6D,61,69,6C,45,46,38,31,36,41,45,37,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,06,1E,00,00,00,09,53,
< 05,89,E0,00,00,00,00,42,05,89,E0,00,00,00,00,42,05,89,E0,00,00,00,18,6D,61,
< 69,6C,46,30,34,41,37,38,45,41,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,
< BF,01,00,00,00,00,00,00,24,2A,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,06,DB,31,00,00,00,00,42,06,DB,
< 31,00,00,00,00,42,06,DB,31,00,00,00,18,6D,61,69,6C,46,31,31,33,44,31,43,31,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,24,64,
< 00,00,00,00,42,08,2C,FF,00,00,00,00,42,08,2C,FE,00,00,00,00,42,08,2C,FF,00,
< 00,00,18,6D,61,69,6C,46,31,44,46,33,34,42,34,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,25,62,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,09,82,39,00,00,
< 00,00,42,09,82,38,00,00,00,00,42,09,82,39,00,00,00,18,6D,61,69,6C,46,32,41,
< 36,30,37,35,43,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,25,DC,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,0A,CF,CA,00,00,00,00,42,0A,CF,CA,00,00,00,00,
< 42,0A,CF,CA,00,00,00,18,6D,61,69,6C,46,33,36,46,32,43,31,32,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,26,58,00,00,00,09,53,
< 0C,21,41,00,00,00,00,42,0C,21,41,00,00,00,00,42,0C,21,41,00,00,00,18,6D,61,
< 69,6C,46,33,36,46,34,41,30,45,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,
< BF,01,00,00,00,00,00,00,06,86,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,0C,21,73,00,00,00,00,42,0C,21,
< 73,00,00,00,00,42,0C,21,73,00,00,00,18,6D,61,69,6C,46,34,33,37,38,44,43,37,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,17,48,
< 00,00,00,00,42,0D,71,70,00,00,00,00,42,0D,71,70,00,00,00,00,42,0D,71,70,00,
< 00,00,18,6D,61,69,6C,46,34,33,37,41,39,43,45,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,06,A6,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,0D,71,9F,00,00,
< 00,00,42,0D,71,9F,00,00,00,00,42,0D,71,9F,00,00,00,18,6D,61,69,6C,46,35,41,
< 30,35,30,39,33,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,17,AE,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,0F,CE,B1,00,00,00,00,42,0F,CE,B1,00,00,00,00,
< 42,0F,CE,B1,00,00,00,18,6D,61,69,6C,46,35,43,39,44,36,32,32,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,17,AE,00,00,00,09,53,
< 10,14,5B,00,00,00,00,42,10,14,5B,00,00,00,00,42,10,14,5B,00,00,00,18,6D,61,
< 69,6C,46,35,43,39,45,35,32,43,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,
< BF,01,00,00,00,00,00,00,06,6C,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,10,14,74,00,00,00,00,42,10,14,
< 74,00,00,00,00,42,10,14,74,00,00,00,18,6D,61,69,6C,46,36,39,33,30,38,30,36,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,18,B8,
< 00,00,00,00,42,11,65,E7,00,00,00,00,42,11,65,E7,00,00,00,00,42,11,65,E7,00,
< 00,00,18,6D,61,69,6C,46,37,35,43,34,36,45,37,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,1A,26,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,12,B7,8A,00,00,
< 00,00,42,12,B7,8A,00,00,00,00,42,12,B7,8A,00,00,00,18,6D,61,69,6C,46,37,35,
< 43,37,30,45,31,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,06,6A,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,12,B7,D0,00,00,00,00,42,12,B7,D0,00,00,00,00,
< 42,12,B7,D0,00,00,00,18,6D,61,69,6C,46,38,32,35,35,41,35,33,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,1B,1C,00,00,00,09,53,
< 14,08,E3,00,00,00,00,42,14,08,E3,00,00,00,00,42,14,08,E3,00,00,00,18,6D,61,
< 69,6C,46,38,32,35,37,34,31,30,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,
< BF,01,00,00,00,00,00,00,06,84,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,14,09,0E,00,00,00,00,42,14,09,
< 0E,00,00,00,00,42,14,09,0E,00,00,00,18,6D,61,69,6C,46,38,45,45,38,41,37,38,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,1C,DA,
< 00,00,00,00,42,15,5A,6D,00,00,00,00,42,15,5A,6D,00,00,00,00,42,15,5A,6D,00,
< 00,00,18,6D,61,69,6C,46,38,45,45,41,32,37,31,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,06,80,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,15,5A,95,00,00,
< 00,00,42,15,5A,95,00,00,00,00,42,15,5A,95,00,00,00,18,6D,61,69,6C,46,39,42,
< 37,42,36,39,35,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,1D,88,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,16,AB,F0,00,00,00,00,42,16,AB,F0,00,00,00,00,
< 42,16,AB,F0,
> 0C,00,00,05,0C,00,00,00,08,00,37,5E,E8,00,41,BB,30,
> 04,00,00,06,04,00,00,00,08,00,37,5E,E8,00,41,BB,30,
< Type: SSH_FXP_NAME, Size: 4612, Number: 1292
< 68,00,00,05,0C,00,00,00,38,00,00,00,18,6D,61,69,6C,46,39,42,37,43,43,45,46,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,06,20,
< 00,00,00,00,42,16,AC,15,00,00,00,00,42,16,AC,15,00,00,00,00,42,16,AC,15,00,
< 00,00,18,6D,61,69,6C,46,41,38,30,45,35,46,31,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,1D,DE,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,17,FD,78,00,00,
< 00,00,42,17,FD,78,00,00,00,00,42,17,FD,78,00,00,00,18,6D,61,69,6C,46,42,34,
< 41,30,44,30,32,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,1D,DE,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,19,4E,F2,00,00,00,00,42,19,4E,F2,00,00,00,00,
< 42,19,4E,F2,00,00,00,18,6D,61,69,6C,46,43,31,33,33,39,44,33,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,1D,DE,00,00,00,09,53,
< 1A,A0,77,00,00,00,00,42,1A,A0,76,00,00,00,00,42,1A,A0,77,00,00,00,18,6D,61,
< 69,6C,46,43,31,33,34,31,37,34,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,
< BF,01,00,00,00,00,00,00,06,7A,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,1A,A0,83,00,00,00,00,42,1A,A0,
< 83,00,00,00,00,42,1A,A0,83,00,00,00,18,6D,61,69,6C,46,43,44,43,38,32,31,42,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,1F,C2,
< 00,00,00,00,42,1B,F2,29,00,00,00,00,42,1B,F2,29,00,00,00,00,42,1B,F2,29,00,
< 00,00,18,6D,61,69,6C,46,44,41,35,39,33,39,35,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,20,E6,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,1D,43,7F,00,00,
< 00,00,42,1D,43,7F,00,00,00,00,42,1D,43,7F,00,00,00,18,6D,61,69,6C,46,44,41,
< 44,44,33,46,32,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,07,FE,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,1D,51,57,00,00,00,00,42,1D,51,57,00,00,00,00,
< 42,1D,51,57,00,00,00,18,6D,61,69,6C,46,44,42,30,32,44,44,43,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,08,4E,00,00,00,09,53,
< 1D,55,48,00,00,00,00,42,1D,55,48,00,00,00,00,42,1D,55,48,00,00,00,18,6D,61,
< 69,6C,46,45,36,36,33,43,36,44,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,
< BF,01,00,00,00,00,00,00,07,3E,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,1E,86,B9,00,00,00,00,42,1E,86,
< B9,00,00,00,00,42,1E,86,B9,00,00,00,18,6D,61,69,6C,46,45,36,45,42,46,34,33,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,21,70,
< 00,00,00,00,42,1E,95,01,00,00,00,00,42,1E,95,01,00,00,00,00,42,1E,95,01,00,
< 00,00,18,6D,61,69,6C,46,45,36,45,44,45,44,45,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,06,7A,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,1E,95,36,00,00,
< 00,00,42,1E,95,36,00,00,00,00,42,1E,95,36,00,00,00,18,6D,61,69,6C,46,45,37,
< 36,46,45,46,36,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,07,56,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,1E,A2,D8,00,00,00,00,42,1E,A2,D8,00,00,00,00,
< 42,1E,A2,D8,00,00,00,18,6D,61,69,6C,46,45,37,36,46,46,33,30,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,07,22,00,00,00,09,53,
< 1E,A2,D8,00,00,00,00,42,1E,A2,D8,00,00,00,00,42,1E,A2,D8,00,00,00,18,6D,61,
< 69,6C,46,45,37,37,30,30,44,39,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,
< BF,01,00,00,00,00,00,00,07,56,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,1E,A2,DB,00,00,00,00,42,1E,A2,
< DB,00,00,00,00,42,1E,A2,DB,00,00,00,18,6D,61,69,6C,46,45,37,37,30,31,41,45,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,07,56,
< 00,00,00,00,42,1E,A2,DC,00,00,00,00,42,1E,A2,DC,00,00,00,00,42,1E,A2,DC,00,
< 00,00,18,6D,61,69,6C,46,45,46,41,31,46,46,31,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,0B,30,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,1F,7E,D7,00,00,
< 00,00,42,1F,7E,D7,00,00,00,00,42,1F,7E,D7,00,00,00,18,6D,61,69,6C,46,46,32,
< 46,36,41,31,30,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,0A,4E,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,1F,D8,3F,00,00,00,00,42,1F,D8,3F,00,00,00,00,
< 42,1F,D8,3F,00,00,00,18,6D,61,69,6C,46,46,33,37,45,43,39,37,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,21,EC,00,00,00,09,53,
< 1F,E6,86,00,00,00,00,42,1F,E6,86,00,00,00,00,42,1F,E6,86,00,00,00,18,6D,61,
< 69,6C,46,46,34,30,32,42,39,36,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,
< BF,01,00,00,00,00,00,00,0A,24,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,1F,F4,5B,00,00,00,00,42,1F,F4,
< 5B,00,00,00,00,42,1F,F4,5B,00,00,00,18,6D,61,69,6C,46,46,34,30,32,43,34,38,
< 30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,0A,72,
< 00,00,00,00,42,1F,F4,5C,00,00,00,00,42,1F,F4,5C,00,00,00,00,42,1F,F4,5C,00,
< 00,00,18,6D,61,69,6C,46,46,34,30,32,45,37,37,30,30,30,35,30,30,41,33,2E,4D,
< 41,49,00,00,00,BF,01,00,00,00,00,00,00,0A,72,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,1F,F4,60,00,00,
< 00,00,42,1F,F4,60,00,00,00,00,42,1F,F4,60,00,00,00,18,6D,61,69,6C,46,46,34,
< 30,41,36,45,39,30,30,30,35,30,30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,
< 00,00,00,0A,72,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,81,80,00,00,00,00,42,1F,F5,2A,00,00,00,00,42,1F,F5,2A,00,00,00,00,
< 42,1F,F5,2A,00,00,00,18,6D,61,69,6C,46,46,46,38,39,37,45,39,30,30,30,35,30,
< 30,41,33,2E,4D,41,49,00,00,00,BF,01,00,00,00,00,00,00,0D,5E,00,00,00,09,53,
< 21,29,C4,00,00,00,00,42,21,29,C4,00,00,00,00,42,21,29,C4,00,00,00,08,6D,61,
< 69,6C,2E,64,61,74,00,00,00,BF,01,00,00,00,00,00,00,0F,0C,00,00,00,09,53,53,
< 5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,FF,00,00,00,00,40,0F,
< C8,45,00,00,00,00,40,0F,C8,44,00,00,00,00,40,0F,C8,45,00,00,00,08,6D,61,69,
< 6C,2E,6D,61,69,00,00,00,BF,01,00,00,00,00,00,29,B2,00,00,00,00,09,53,53,5F,
< 4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,80,00,00,00,00,42,26,99,
< DC,00,00,00,00,41,0E,1E,D6,00,00,00,00,42,26,99,DC,00,00,00,0E,6D,61,73,74,
< 65,72,6E,6F,64,65,2E,74,78,74,00,00,00,BF,01,00,00,00,00,00,00,00,50,00,00,
< 00,00,3E,A9,26,D1,00,00,00,00,3E,A9,26,D1,00,00,00,00,3E,A9,26,D1,00,00,00,
< 0D,6D,68,73,32,34,30,33,37,35,2E,72,74,6E,00,00,00,BF,01,00,00,00,00,00,00,
< DB,00,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,
< 81,E8,00,00,00,00,40,4C,54,EF,00,00,00,00,40,4C,54,EF,00,00,00,00,40,4C,54,
< EF,00,00,00,11,6D,6F,6E,69,74,6F,72,5F,6C,6F,67,69,6E,2E,63,6F,6D,00,00,00,
< BF,01,00,00,00,00,00,00,10,24,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,E8,00,00,00,00,41,90,D6,9F,00,00,00,00,41,90,D6,
< 9F,00,00,00,00,41,90,D6,9F,00,00,00,03,6E,66,73,00,00,00,BF,02,00,00,00,00,
< 00,00,02,00,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,
< 00,00,41,E9,00,00,00,00,41,01,0E,48,00,00,00,00,41,01,0E,48,00,00,00,00,41,
< 01,0E,48,00,00,00,10,6E,69,67,68,74,6C,79,63,6C,65,61,6E,2E,63,6F,6D,00,00,
< 00,BF,01,00,00,00,00,00,00,02,E0,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,
< 00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,3E,C3,B8,3C,00,00,00,00,3E,C3,
< B8,3C,00,00,00,00,3E,C3,B8,3C,00,00,00,07,6E,6C,70,2E,74,78,74,00,00,00,BF,
< 01,00,00,00,00,00,00,79,98,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,
< 04,53,41,49,43,00,00,81,E8,00,00,00,00,40,3E,0B,53,00,00,00,00,40,3E,0B,53,
< 00,00,00,00,40,3E,0B,53,00,00,00,0A,6E,6C,70,73,72,74,2E,74,78,74,00,00,00,
< BF,01,00,00,00,00,00,00,79,98,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,3E,10,CD,00,00,00,00,40,3E,10,
< CD,00,00,00,00,40,3E,10,CD,00,00,00,0B,70,6E,61,7A,65,72,6F,2E,74,78,74,00,
< 00,00,BF,01,00,00,00,00,00,00,82,08,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,
< 00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,42,25,A0,DF,00,00,00,00,42,
< 25,A0,DF,00,00,00,00,42,25,A0,DF,00,00,00,07,71,75,65,75,65,2E,78,00,00,00,
< BF,01,00,00,00,00,00,00,9F,2A,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,
< 00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,19,9B,8B,00,00,00,00,40,19,9B,
< 89,00,00,00,00,40,19,9B,8B,00,00,00,11,71,75,65,75,65,5F,72,65,73,74,61,72,
< 74,2E,63,6F,6D,00,00,00,BF,01,00,00,00,00,00,00,02,C0,00,00,00,09,53,53,5F,
< 4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,3E,92,9D,
< B6,00,00,00,00,3E,92,9D,B6,00,00,00,00,3E,92,9D,B6,00,00,00,0A,72,75,6E,64,
< 73,6D,2E,63,6F,6D,00,00,00,BF,01,00,00,00,00,00,00,00,2C,00,00,00,09,53,53,
< 5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,3E,A9,
< 25,B6,00,00,00,00,3E,A9,25,B6,00,00,00,00,3E,A9,25,B6,00,00,00,0B,73,65,73,
< 73,69,6F,6E,2E,6C,6F,67,00,00,00,BF,01,00,00,00,00,00,00,00,ED,00,00,00,09,
< 42,23,1D,7E,00,00,00,00,42,23,1D,5F,00,00,00,00,42,23,1D,7E,00,00,00,03,73,
< 68,63,00,00,00,BF,02,00,00,00,00,00,00,02,00,00,00,00,09,53,53,5F,4E,4F,4C,
< 41,4E,44,00,00,00,04,53,41,49,43,00,00,41,ED,00,00,00,00,3E,81,AA,70,00,00,
< 00,00,3E,49,11,38,00,00,00,00,3E,81,AA,70,00,00,00,1B,73,69,74,65,73,70,65,
< 63,69,66,69,63,5F,63,6F,6D,2E,74,70,75,4A,4F,55,52,4E,41,4C,00,00,00,BF,01,
< 00,00,00,00,00,00,00,F0,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,
< 53,41,49,43,00,00,81,E8,00,00,00,00,40,43,25,9B,00,00,00,00,40,43,24,FF,00,
< 00,00,00,40,43,25,9B,00,00,00,07,73,71,61,2E,6C,69,73,00,00,00,BF,01,00,00,
< 00,00,00,00,00,5C,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,
< 49,43,00,00,81,E8,00,00,00,00,40,3C,CB,3B,00,00,00,00,40,3C,CB,3B,00,00,00,
< 00,40,3C,CB,3B,00,00,00,03,73,73,68,00,00,00,BF,02,00,00,00,00,00,00,02,00,
< 00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,41,80,
< 00,00,00,00,3E,81,AA,70,00,00,00,00,3D,43,CD,FE,00,00,00,00,3E,81,AA,70,00,
< 00,00,04,73,73,68,32,00,00,00,BF,02,00,00,00,00,00,00,02,00,00,00,00,09,53,
< 53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,41,E9,00,00,00,00,3F,
< B2,1B,71,00,00,00,00,3F,B2,1B,71,00,00,00,00,3F,B2,1B,71,00,00,00,07,73,73,
< 6C,2E,63,61,70,00,00,00,BF,01,00,00,00,00,00,00,1B,CF,00,00,00,09,53,53,5F,
< 4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,42,25,C5,
< F9,00,00,00,00,42,25,C5,C9,00,00,00,00,42,25,C5,F9,00,00,00,0E,73,74,61,72,
< 74,71,75,65,75,65,2E,63,6F,6D,00,00,00,BF,01,00,00,00,00,00,00,00,1E,00,00,
< 00,00,3E,A3,EB,36,00,00,00,00,3E,A3,EB,36,00,00,00,00,3E,A3,EB,36,00,00,00,
< 0D,73,74,6F,70,71,75,65,75,65,2E,63,6F,6D,00,00,00,BF,01,00,00,00,00,00,00,
< 00,24,00,00,00,02,32,37,00,00,00,04,31,30,30,30,00,00,81,E8,00,00,00,00,3E,
< A3,EB,45,00,00,00,00,3E,A3,EB,45,00,00,00,00,3E,A3,EB,45,00,00,00,0A,74,61,
< 70,65,5F,65,72,72,73,2E,00,00,00,BF,01,00,00,00,00,00,00,52,F2,00,00,00,09,
< 41,08,D4,46,00,00,00,00,41,08,D4,45,00,00,00,00,41,08,D4,46,00,00,00,0E,74,
< 61,70,65,5F,65,72,72,73,2E,64,69,61,67,00,00,00,BF,01,00,00,00,00,00,00,52,
< F2,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,
< E8,00,00,00,00,41,08,D6,68,00,00,00,00,41,08,D6,68,00,00,00,00,41,08,D6,68,
< 00,00,00,09,74,65,6D,70,2E,64,69,61,67,00,00,00,BF,01,00,00,00,00,00,06,EE,
< 99,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,
< E8,00,00,00,00,40,1F,A5,31,00,00,00,00,40,1F,A5,2C,00,00,00,00,40,1F,A5,31,
< 00,00,00,08,74,65,73,74,2E,63,6F,6D,00,00,00,BF,01,00,00,00,00,00,00,00,8A,
< 00,00,00,00,3E,81,AA,70,00,00,00,00,3D,C7,CC,27,00,00,00,00,3E,81,AA,70,00,
< 00,00,0A,74,65,73,74,65,72,2E,74,78,74,00,00,00,BF,01,00,00,00,00,00,00,00,
< 16,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,43,00,00,81,
< E8,00,00,00,00,3F,5C,A2,D1,00,00,00,00,3F,5C,A2,B7,00,00,00,00,3F,5C,A2,D1,
< 00,00,00,08,74,6D,63,39,2E,74,78,74,00,00,00,BF,01,00,00,00,00,00,00,06,CE,
< 00,00,00,00,40,3F,4D,AA,00,00,00,00,40,3F,4D,AA,00,00,00,00,40,3F,4D,AA,00,
< 00,00,10,74,72,61,6E,73,6C,61,74,65,5F,69,70,2E,63,6F,6D,00,00,00,BF,01,00,
< 00,00,00,00,00,03,72,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,
< 41,49,43,00,00,81,E8,00,00,00,00,40,C4,38,B4,00,00,00,00,40,C4,38,B4,00,00,
< 00,00,40,C4,38,B4,00,00,00,07,77,61,74,63,68,65,72,00,00,00,BF,02,00,00,00,
< 00,00,00,04,00,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,00,00,04,53,41,49,
< 43,00,00,41,E9,00,00,00,00,3E,BB,C8,92,00,00,00,00,3E,BB,C8,7A,00,00,00,00,
< 3E,BB,C8,92,00,00,00,0F,77,65,65,6B,6C,79,63,68,65,63,6B,2E,63,6F,6D,00,00,
< 00,BF,01,00,00,00,00,00,00,01,92,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,44,00,
< 00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,3E,81,AA,70,00,00,00,00,3D,ED,
< E7,C5,00,00,00,00,3E,81,AA,70,00,00,00,0B,5F,6E,6C,70,34,36,38,2E,64,61,74,
< 00,00,00,BF,01,00,00,00,00,00,00,B9,B2,00,00,00,09,53,53,5F,4E,4F,4C,41,4E,
< 44,00,00,00,04,53,41,49,43,00,00,81,E8,00,00,00,00,40,27,54,4D,00,00,00,00,
< 40,10,D9,24,00,00,00,00,40,27,54,4D,
< 65,00,00,06,04,00,00,00,00,00,00,00,02,4F,4B,00,00,00,02,65,6E,
* Out of memory
Your SFTP server violates SFTP specification, at least with version 4 of the protocol. I have implemented workaround for the bug, you may download modified version. Or you may try to upgrade your server, I've noticed that there is F-Secure SSH server 5.0 available already.
Technical details:
The server includes flag SSH_FILEXFER_ATTR_UIDGID (0x00000002) in SFTP packet SSH_FXP_NAME, while specification for SFTP 4 says:
In previous versions of this protocol flags value 0x00000002 was
SSH_FILEXFER_ATTR_UIDGID. This value is now unused, and OWNERGROUP
was given a new value in order to ease implementation burden.
0x00000002 MUST NOT appear in the mask. Some future version of this
protocol may reuse flag 0x00000002.
What is worse, the server does not include the data announced by the flag (UID/GUID). Otherwise the WinSCP would be able to handle the bug gracefully.
