ls --full-time does not work on command-line
Torsten
I connected to a server via command-line using the latest winscp-version. I tried the command "ls" which works. But I want to have the full timestamp and so I tried "ls --full-time" which does not work
winscp> ls --fulltime
Error listing directory '--fulltime'.
Command 'ls -la "./--fulltime"'
failed with return code 2 and error message
./--fulltime: No such file or directory.
(A)bort, (R)etry, (S)kip: Skip
winscp> ls -la -full-time
Too many parameters for command 'ls'.
What is the mistake?
Thanks.
Regards,
Torsten
Re: ls --full-time does not work on command-line
WinSCP is not SSH terminal, it is SFTP client. You cannot execute remote command this way. 'ls' is local command of the client. It can no options like '--fulltime'.
Anyway what do you miss in timestamp WinSCP displays?
shtofff
How run "ls -la" ?
i'm running from command-line:
C:\Program Files\WinSCP>WinSCP.com root:mypassword@127.0.0.1:22
and when trying to run "ls -la" i'm getting Unknown command error:
winscp> ls -la
Unknown switch 'la'.
how can i solve it when running from command-line ?
OK,
i found the solution.... i had to put "call" before:
winscp> call ls -la
total 92
drwxr-x--- 6 root wheel 306 Dec 28 21:13 .
drwxr-xr-x 24 root wheel 884 Dec 8 22:18 ..
-rw------- 1 root wheel 5542 Dec 25 19:27 .bash_history
-rw------- 1 root wheel 35 Dec 11 16:45 .lesshst
drwxr-x--- 8 root wheel 272 Dec 10 12:05 Library
drwxr-xr-x 2 root wheel 68 Jul 20 03:14 Media
drwxr-xr-x 3 root wheel 136 Dec 28 17:40 gg
-rw------- 1 root wheel 78205 Dec 25 18:35 iopd.log
drwxr-xr-x 2 root wheel 68 Dec 28 21:13 zz
thanks anyway
