Topic "Error skipping startup error message. Can't detect command return code."
guest
WinSCP 2.2.0 Build 122 fails to
setup session.
ttssh,putty,wcp 2.0.0 all have no problem
getting thru to that server.
How can i make it run?
It seems to have trouble with the login
sequence.
The server requires a terminal emulation name
or a simple "<CR>"
Connecting to host...
Starting session...
Pressing <OK>
Boxes+Aplication closes...
WinSCP 2.0.0 Build 89 continues and
cleanly connects to the server
With active logging to window:
Assertion failed: (LogMemo->Parent == this) &&
(LogMemo->OnChange == LogMemoChange),
file C:\Martin\Projekty\WinSCP2\forms\Log.cpp, line 77
(That's another problem...)
Logging only to file:
. Authentication successful
. Started compression
. Initialised zlib (RFC1950) compression
. Initialised zlib (RFC1950) decompression
. Started session
. Doing startup conversation with host (shell).
> echo "WinSCP: this is end-of-file:0"
! stty: stdin isn't a terminal
< Terminal type [vt102]: Terminal is echo "WinSCP: this is end-of-file:0"
* (ECommand) Error skipping startup message.
. Closing connection.
Seems to be the same problem as in thread:
"WinSCP fails to connect my OpenSSH_3.5p 1(on w2k
server w/ sp3)"
which ends in:
! setgid: Invalid argument
. Server sent command exit status 1
* (ESshFatal) Error skipping startup message.
